2006 Toyota 4runner Limited 4.7L V8 4x4 - 2 Owner - $8,950 - Roswell, NM
Thanks, I'm hoping someone needs a stock rig. She is homely, but reliable, and has had a lot of small things repaired/replaced - exterior window seals, hood and hatch struts, sway bushings and links, all the small stuff that doesn't need to be addressed....but is nice when it is.
Post some photos of the frame, you already have 4X4 and the V8 going for you a rust free frame will help sell it faster, those are the big 3 desired options of the 4TH Gens!
I will at some point, yes pics always help - Carfax proves life in Central/Southern AZ and Southern NM (both dry deserts) but you are right - pics needed, I did leave room for front and back undercarriage pics on ad. She also has other goodies not mentioned/pictured - ie. she also has SlyFox's SAI pump bypass module installed to keep that system from having issues - more small stuff, similar to this, not listed that the new owner will appreciate.
Wish you were closer. I'm in yuma
Fly into ROW direct on AA and drive away. ;)
AndiGarage
