What the Kodiak K2 Can charge
I am interested in this package. What can I use this set up for? Other than using a laptop, what can this set up power? I like to have a fridge, charge my phone, use my laptop and maybe LED lights? Excuse me for all the questions but this is all new to me. If I am going to spend this much money, I like to know what it can do for me. I like your products because it's the best set up. If I get this set up, do I need anything else or is this pretty much ready to use?
It is a very powerful unit in a small package and more competitively priced compared with a Goal Zero Yeti 1400 Lithium that is 43.7lbs:
WHAT IT CAN POWER?
The K2 Solar Generator can power just about anything, anywhere.
Smartphones (5-7 watts): 100+ hours
Tablets (25-40 watts): 40+ hours
Laptops (50 watts): 20+ hours
Electric Blanket (Queen Size, 75 watts): 14 hours
50″ LED LCD TV* (65 watts) : 16 hours
Microwave (1,000 watts): 1 hour
Refrigerator* (18 cu ft., 20% duty): 33 hours
Chest Freezer (9 cu ft., 15% duty): 50 hours
Sump Pump (1/3 HP): 2.5 hours
Basecamp LED Light (6 watts) : 183 hours
*Energy Star Certified Appliance
POWER SPECS
Internal Battery: 1,100 watt hours (90 amp @12.6 volts), Lithium NMC
Battery Life Expectancy: Up to 2,000 Cycles or 10 Years
AC Inverter: 1,500 watts continuous pure sine wave, 3,000 watts starting surge
Charging: 500 watts max input, 3 hour recharge time at max input
Battery Expansion: Compatible with both 12.6 deep cycle lead acid/AGM batteries & InergyLithium-Ion Batteries (soon to be announced)
MPPT Charge Controller: 500 Watt (30A) Maximum Input. Charges in as little as 3 hours in ideal sun conditions.
2 USB-C Charge Ports: 5V 3A
2 USB Qual Comm 3.0 Charge Ports
3 Position Power Switch: Allows user to charge devices via the USB, USB-C, and 12V output ports without having to turn on the inverter
PRODUCT SPECS
Charging Temperatures: 32°F to 104°F
Discharging Temperatures:20°F to 115°F
Dimensions: 14″ W x 7″ H x 8″ D
Weight: 25 lbs.
Warranty: 1-Year
EC8 Input Plug: Creates an extremely user friendly, plug and play interface
NOT Compatible with MC4 to Neutrik Adapter.
ONLY accepts Inergy solar panels, car charger, standard AC charger and Quick wall charger.
REQUIRES 30′ Neutrik to EC8 Solar Panel Cable to connect to previous inergy panels.
Shoulder Carrying Strap
AC Charger Included
