2014 4Runner Lift kits
4RnrArmy
Greetings,
I was curious if any one had suggestions on which lift kit to use on a 2014 TE, I mostly use it for travel to and from work, and off roading during hunting seasons. I have looked at toytech and Procomp, but I am unsure on what company to go with, any suggestions would be appreciated.
V/R
4RnrArmy::sniper:
Greetings,
V/R
4RnrArmy::sniper:
Your budget helps narrow things down. There's a ton of info on here, especially in the stickies at the top. Plan your budget first, any future mods that weigh a lot like a winch or bumper, and go from there. Too many options to list out.
^^ Very capable so you don't need a ton to get a bit more clearance . Depends on tires & what your look is gonna be 285s ,255s skinny , 275s all that kinda stuff . Check Total automotive lv he offer's new bilsteins 6112 & others . You can kill your brain looking at all the builds .
Doesn't sound like you need a lift kit for any of those things you do (unless it's for looks). First order of business is to get some better tires.
lift kit
Yeah I agree first order of business is new tires I currently have 265/70/17 on it. I am wanting to a a bit of additional height out of the new tires but I do not want to put tires on that will cause rubbing in the wheel well. Can you possible point me to a tire that might allow me to do this: Called local toyota dealership they said I couldnt fit anything higher than a 265/70/17 on it with out a lift kit, is this true?
I was looking at BFG KO2 LT275/70R17 or LT285/70R17.
Any additional advice would be appreciated.
As far as the complete cost I am looking at getting
New wheels, tires, skid plates, and possible lift for around 4K if possible. Only reason I am looking at skid plats is that some of the areas here on Fort Bragg are rough getting to during deer season.:50cal:
seltzernator
