2016 Puddle Light Write up.
I recently upgraded every last light on my truck to cool white LED's all were fairly simple and found write ups for all, except for the puddle light write up or video. So here, it is. It's my first, so bear with me.
STEP 1: Turn mirror inward as far as possible and gently pull off, it will sounds bad but it won't break anything as long as you're gentle. After that, follow these pictures below.
Here, you can see the difference in the bulbs. MAKE SURE YOU REALLY PRESS THE NEW BULB IN, I PUT EVERYTHING BACK TOGETHER AND HAD TO RE-DO IT. The connection is very finicky.
Thanks for the write up. Awesome job. Do you have a list with bulb type/# with a location for quick easy reference? I want to do get this done this weekend. Looks great.
Sent from my SAMSUNG-SM-N930A using Tapatalk
Xenon depot has a good reference chart that lists them.
The vanity lights are stupid crazy bright, and I got those at carid.com as well.
Hey, boss. I made this for you. It's from carid.com I hope it helps, you can run the larger 194 bulbs in certain areas but I decided that the shorter ones sufficed. Good luck!
The puddle lights are from diodedynamics.com and are the only ones, easy find.
AndiGarage
