2017 TRD Off Road Premium - TPMS?
CatahoulaManiac
I apologize if this has been covered somewhere, I did search and couldn't find anything answering this question and the manual wasn't clear.
Do the TRD OR premium models have TPMS? If so, does it not read current pressure and only indicate when it's low?
The reason this question has popped up, I've bought the TRD black alloy wheels to put on with a set of BFG's, and I'm selling my factory wheels and tires to a guy I work with. For simplicity, I don't want to have to break down tires to get the valve stems out if there is TPMS.
Do I need to buy some TPMS valve stems for my new wheels, or is there no TPMS system so regular old valve stems will work?
Yes, there is TPMS. You will need to swap them over or buy new ones unless you don't mind having a dash light....
only shows when its LOW
i have aftermarket head unit with idatalink maestro and i can see PSI of each wheel and temp in my headunit
For a bit more information, does anyone know if the TPMS reading is available via the ODB II port, so you can read the actual pressure?
yes
my headunit displays tpms data, because it ties into 1 wire on the obd2. So nearly positive that it is getting tmps data from that 1 wire.
yes
This is the stock head unit, or aftermarket? If stock, where is the TPMS data found? I've got a 2017 with Entune and couldn't find the actual pressure number anywhere.
