2018 sr5
MJCIII
Member
Hey All,
I have a 2018 SR5,while driving at speeds up to 60 MPH i have a slight vibration feel about every 2 seconds, like driving the rumble strip but not as bad. The vibration does not increase with speed, it is consistant 2 secs. After 60 mph it is gone, checked everything, rearend, transfer case, drive shaft, front end. Greased Driveshaft as well, dealer never touched it on any services, hence why i wouldnt bring to a dealer for anything. Any help would be appreciated.
Thankyou
Hey All,
I have a 2018 SR5,while driving at speeds up to 60 MPH i have a slight vibration feel about every 2 seconds, like driving the rumble strip but not as bad. The vibration does not increase with speed, it is consistant 2 secs. After 60 mph it is gone, checked everything, rearend, transfer case, drive shaft, front end. Any help would be appreciated.
Thankyou
possibly need your tires balanced again
Still there in 4wd? If not, possibly needle bearing. FWIW, my 2016 has had an intermittent vibration in the driver side foot well that sort of matches what you are describing since new, I've learned to live with it.
Sent from my SM-G998U using Tapatalk
ill check while in 4WD next time i drive it, if so then the needle bearing. For those who said probably needs to balance tires, family business is a mechanical shop. Tires are perfectly balanced, just re checked them and they are good. thankyou all so far for your responces
Since the OP may not be familiar with what you mean by "needle bearing", he should look up T-SB-0012-19: https://static.nhtsa.gov/odi/tsbs/2019/MC-10154805-9999.pdf
Thankyou for this information, this is the issue and has been diagnosed by toyota. i have been in contact with toyota as my warranty is out by 3k miles and they dont want to repair this as a warranty issue. I have been dealing with this issue for months and it started while still with-in warranty. My issue is if Toyota knew there was a potential issue with this why not send me some sort of notice to let owners know about it so i could have it possiby diagnosed.
AndiGarage
