2019 off road vs limited compare?
When the center diff is locked you have 4WD, when unlocked you have AWD (all wheel drive). The difference is with 4WD 50% of the power goes to the front wheels and 50% to the rear. A unlocked center diff allows slippage between front and rear axles. so it not locked in at 50/50. AWD is good for on road and 4WD is good for off road.
Well done here.
Wheels
Locking the center diff makes it equivalent to an SR5 when you have the SR5 in 4WD. 20" wheels on the Limited are not ideal for hard-core off-roading as you can only air them down so much. I think I read the approach angle (or maybe departure) on a Limited isn't as good as an SR5 as well.
I got lucky. Just bought’19 certified limited. Has original Bridgestone P265/70SR17 tires. Looking at Falken - but they don’t show that size in recommended AT3. Any other tire advice would be appreciated
I went with the BFG K02. Very pleased with them but I've heard they may be hard to balance.
