4th Gen 4Runner (2003-2009) 32" Lower Bumper LED Light Bar Kits: Flush & Hidden | Cali Raised LED
Caliraisedled
Official Vendor
4th Gen 4Runner (2003–2009) 32" Lower Bumper LED Light Bar Kits: Flush & Hidden, updated Nov 2026
Jake from Cali Raised LED here. Here's the current info for the 4th gen lower bumper light bar kits. Ask questions below.
Two styles
  • Flush: the 32" bar sits flush with or tucked into the lower bumper opening for a clean look.
  • Hidden: the 32" bar mounts on the inside of the lower bumper, out of sight.
Both styles
  • Bolt-on. No drilling or cutting.
  • Built for a 32" LED bar.
  • About 1–2 hours with basic hand tools.
  • Brackets are fabricated in-house in Fort Worth, Texas. The LED bars are made overseas.
Kit or brackets only
All 4th gen lighting kits (ditch lights too): https://caliraisedled.com/collections/2003-2009-toyota-4runner-led-light-mounts-combos
Questions: reply here, call 888-385-5036 or email [email protected].
Welcome
Cali Raised Led
www.CaliRaisedled.com
Phone (714)-388-7020 Or (714)604-6426 Email [email protected] Instagram @cali_raised_led
2003-2009 Toyota 4Runner 32" Flush Lower Bumper Brackets
https://caliraisedled.com/products/2...umper-brackets
Brackets $60.00
Brackets with 5d 32" Led Bar Combo Beam or Spot Beam
Toyota 4Runner Flush 32" LED mounting brackets. Laser cut and made from 3/16" thick steel, these mounts are made to hold your LED light bar while requiring no vehicle modification except for you to cut out the lower grill plastic. The Flush style places the LED in the lower grill and it sits almost flush with the edge of the bumper. Turn the LED on and get great light while using your factory bumper.
Features:
- 3/16" steel construction with welded gussets
- Black powder coat
- 100% bolt on (except your lower grill)
- Includes all required hardware
- Made in the USA
https://caliraisedled.com/collection...mper-brackets?
Brackets $60.00
Brackets with 5D 32" $269.99 Combo Beam or Spot Beam
THESE ARE THE 2003 - 2009 4RUNNER STEALTH LED MOUNTING BRACKETS. THEY ARE DESIGNED TO ALLOW THE INSTALL OF A 32" LED LIGHT BAR IN THE LOWER GRILL. THE MOUNTS ARE 100% BOLT ON AND REQUIRE NO MODIFICATION TO YOUR TRUCK.
CNC cut 3/16" thick steel
MIG welded with anti-vibration gusseting
Powder coated semi gloss black mini texture
Height and depth adjustable
Free shipping
Bump
I have had one of these flush mount light bars installed for a couple months now. Love it! I often drive at night in the country coming home from work and this thing lights everything up. I had to grind a small notch out of the driver side brack because I had a hose running up that was rubbing on it. My 4Runner has a rebuilt status so it's possible this hose was routed differently than the factory cause I have not heard of anyone else having issues fitting. I ordered the light bar cover for a few road trips as it's technically illegal to have these lights uncovered. Unfortunately the glue that came with the cover didn't seem to be strong enough as after a day of the vehicle sitting in the sun the glue melted right off and disappeared with the cover and all the magnets in a ditch somewhere. Currently looking for another solution for covering my light bar.
Besides that little thing though this setup is amazing, hella bright and a pretty easy install. Some people have cut out their lower grill but I was able to pop mine out so I can always reinstall if I decide to go back to stock.
Thanks for the review, glad you like the setup!
Already have the brackets. Love them, but need a new light. Sent you a PM on Tacoma world as I did not realise you were on T4R forum also.
[MENTION=164250]Caliraisedled[/MENTION]
Living in California, I have to have a front license plate. How well does the stealth lower bumper work with a license plate? Does to much light get blocked or does enough get through to make the light worth it? Anyone with experience.
Not sure what part of California you're in but I've been driving without a front license plate for about 10 years now and never been given a ticket.
Bought a set. Will confirm fit after install. I have a front mount license plate, so may try to relocate that...
You can relocate your license plate or have it mounted behind it, the license plate will block a little of the light but I would just relocate it
Welcome
Cali Raised Led
https://caliraisedled.com/collectio...toyota-4runner-32-flush-lower-bumper-brackets
Brackets $60.00
Features:
- Black powder coat
- Made in the USA
https://caliraisedled.com/collectio...yota-4runner-32-stealth-lower-bumper-brackets
Brackets $60.00
Free shipping
This is awesome. I was just researching last night how to install a led bar behind my lower grill. I just found my solution. I know what I'm asking for my birthday next month.
Let us know if you have any questions about the kit. Its a super easy install which is a great addition to your 4runner
youngrk
