2nd Gen 4Runner LED Tail light experiment
Dropzone
i have a pile of spare parts and left overs from the trekker.*3rd Gen Trucks have a ton of decent LED taillights on the market but aren't compatible with 4runners due to the mounts. No LED aftermarket LED tail lights that i can find for 2nd gen 4runners and stock taillights even with bright LED replacement 1156 and 1157's leave a lot to be desired so decided to experiment
220* for 12 minutes did the trick
20171115_115127-1*
20171115_120936*
throw tail lights from Trekker and some clear KC LED for signals
20171115_121735*
running lights
20171115_122532*
brake and turn signals
20171115_122849*
not too bad with faded stock lenses*
So went to polish the lenses since they are faded as heck, they cracked like crazy
20171116_132114*
pretty much a waste of time...I was heating and separating the housings from the lenses since that is how you do it for headlights...well a set of trashed housings and some frustration i think,*
Hey idiot why didn't you just cut out the back of the housing to mount the LED's (amber light for mock up), Version 2.0 won't have as big of hole cut for the brake light.
20171116_131232**
would have been time and money ahead if I would have done that the 1st time around.*
so said screw it and ordered a new set of aftermarket housings off ebay since the last good set of housing I have has 25 year old lenses and what to keep one good set unmangled.
Also ordered a set of Clear LED brake lights since they should show through the red brake light better.
overall cost will be about $70 and lessons learned.
Version 2.0 should be done next week when stuff comes in and I'll fiberglass the LED's into the new housings
LED Taillight Version 2.0
Finished up 2nd gen LED conversion 2.0
Came out better than 1.0 but could use a little improvement. I used too much epoxy and it ran down into the lens but the output is awesome over what I had
20171130_120113 by ocdropzone, on Flickr
20171130_120246 by ocdropzone, on Flickr
20171201_154454 by ocdropzone, on Flickr
20171201_154516 by ocdropzone, on Flickr
20171201_172920 by ocdropzone, on Flickr
night shots don't do it justice, the output over 1157/1156 LED's is awesome
20171201_172955-1 by ocdropzone, on Flickr
parts List for LED converson
got a couple of messages on instajunk and another forum asking for parts and price list so here you go
for the lights I ended up ordering a set of new housings off ebay. I ended up cracking a few lens trying to separate them from the housing. It was easier to try a brand new cheap set
I was able to use the 4" hole saw I had when i did the round lights in the the Trekker. I wasn't able to get all the way through as I ended chewing up a little bit of the inside of one lens.
But it gave me a good outline and I was able to finish cutting the rest to get a rough fit using my dremel. The backside isn't pretty but if I ever make another set i know what to expect
Here is the parts list:
Housings I got on ebay
a pair for $50 shipped, over all quality is decent for the money and if I ended up destroying them during the experiment I wasn't out a ton of cash
https://www.ebay.com/itm/Pair-Tail-...ash=item36043574e6:g:SSoAAOSwBt5ZHca2&vxp=mtr
Brakes lights I was going to order some from Amazon like this, but I found a set of clear ones brake lights I used on the 81 at some point $25/pair
https://www.amazon.com/gp/product/B00K5J23Z6/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
Turn signals I used a set of KC Cyclone LED's in Clear, again left over in the stash of junk from the 81
https://www.amazon.com/KC-HiLiTES-1...d=1512257173&sr=1-1&keywords=kc+cyclone+clear $26 each, $52 a pair
misc epoxy (i used too much and it dripped into the lens) $10-12 from Ace hardware
so realistic cost was $135'ish but I consider the cost to me more like $60-65 since some parts was stuff i had around few at least a few years.
I used a couple of housings that were the originals on the truck and a set i was given. Still have a couple i bought that will stay on the shelf for back ups. Had a guy ask me today where I got them when i was X-mas shopping. He said that I should have just used 3rd gen truck lights, nope not gonna work unless you do some body work.
For a little more money this set of Euro lenses would be cool using an Amber KC LED for the turn signal
https://www.ebay.com/itm/1990-1991-...sc:ShippingMethodStandard!97078!US!-1&vxp=mtr
