2uz Tune Up
Kryptoroxx
Familiar with yota, unfamiliar with the 2uz. Starting to plan a spring tune up on a new to me. This has about 150k and looks like it was reasonably well maintained. PO said he changed the belt the year prior but no sticker. I might just change it so I know exactly what mileage it was done at.
Plugs and wires
Vaccum line inspection
Seafoam treatment (oil, intake, fuel tank)
Throttle body clean
Maf clean
Fuel system treatment
Air filter box clean and probably amsoil filter
Also I have a tick so I'll probably be dropping 1500 into the exhaust setup with shorty headers, high flow cats, and stainless Walker exhaust. Just don't want to do that in the winter time since it is kind of tight in the engine bay to get the manifolds off.
Anything else?
Sent from my SM-G965U using Tapatalk
Diff and transfer case fluid change
Spark plug change
Coolant change
Engine air filter
Cabin air filter
I can't recall replacing plug wires on any of my Toyotas
I've been told numerous times at the dealer, in clubs, and at my current shop, that they're designed to last the life of the motor and only replace them if you have a problem.
Replacing them makes them a maintenance item, once they're parts store special wires that degrade with time/heat/use.
Plugs and wires
Throttle body clean
Maf clean
Anything else?
4Th gen T4Rs neither V6 or V8 have spark plugs wires, each cylinder has it's own coil, so no need for spark plug wires.
Jhunt
