2wd trans
01thunder
anyone drop theres yet? any secrets, mishaps, etc? the rear main is leaking on my truck and i just may have to drop the trans and replace the seal. it looks pretty easy.
Should be the same process as any 4WD trans, just make sure to plug up the driveshaft hole before you tip it backwards or the fluid will drain out, that's about the only thing different besides not having an extra 100 pounds of transfer case to throw around.
Crookedcat
