3rd gen 3.4 flexplate change
studebaker
Unable to find info regarding changing out the flexplate on a 99 3.4.
I have to change this one due to chipped teeth on ring gear.
Any advice?
Thanks!!
Any advice?
Thanks!!
Remove transmission, replace flex plate, reinstall transmission. I would consider replacing the rear main seal while you are there.
Yes good idea on the mail seal..:)
Thanks for the reply's.
I had anticipated changing the rear seal and have the rear seal kit (seal and cover gasket) along with the flexplate.
This is a rwd version.
Process will be very similar except you don't have a transfer case for the 4WD.
Other then that darn near identical. :-)
DionicioLives
