3rd gen purchase help
travisenglish21
Hey everyone,
If I am looking at a 3rd gen t4r what would anyone recommend that the highest I should go on existing miles? Don't get over 200,000, 300,000? Most of them in my area, salt lake city, seem to around that mileage.
I wouldn't be afraid of higher mileage under two conditions:
1. seller has records and has done most all reasonable maintenance
or
2. you are willing to do all required maintenance*
Either way, if the price is right and you are willing to make the total investment (purchase plus maintenance) then I'd not be afraid of buying a 3rd gen in good shape with up to 200K miles on it. Also, check for rust from in all the usual areas: undercarriage, shock mounts, frame rails and cross members (remove skid plates to inspect)
Anything beyond 200K and I personally would want to see maintenance records
Regardless you might want to pull a Carfax to make sure no major accidents or salvage title
*plan on doing all required maintenance
-LBJs
-timing belt
-drive shaft universal joints
-all fluids
-radiator
-wheel bearings
ETC
Hey everyone,
Depends on your budget - if you're looking for something under 5 grand - I'd be more concerned with maintenance history than focusing too hard on mileage if all you see is between 200 - 300k - check and see if the lower ball joints have been done, timing belt, water pump, suspension components, check for any sudden changes in the radiator or transmission etc.
Recommend checking out the classifieds in this forum as well - at least people here know what they are doing more or less and a lot of the preventative maintenance has been done.
http://www.toyota-4runner.org/sale-...nder-ed-4x4-5-spd-man-166k-$5-4k-chicago.html
If you get a cheap higher mileage example with none of the preventative maintenance done, you would have done better to spend more on the car and get something with lower miles/newer.
From my experience with these trucks, at least with the 3.4 (5vz-fe) they are pretty bullet proof. However like with any engine its good to have a history of maintenance etc. Miles are important, but maintenance is even more important. A truck with 150K and poor maintenance could be a bigger problem than 300k and proper maintenance.
I had a 98 with 280k on the clock. I did all of the things I thought were a good idea as I did not have any records on it (radiator, timing belt, plugs, wires, valve covers etc.). That thing ran like a top even with high miles.
So my advice is that high miles doesn't necessarily mean anything bad, whether it was taken care of it more important. Of course the lower the miles is ideal, but as long as you do a really thorough once over a high mileage truck can still be great.
Hey everyone,
I would be wary of rust in SLC. My brother is down there and advises to never buy one there. I would be looking in CO or eastern Idaho. Just my .02
Or look in Arizona or Southern California. Those are considered the rust free states
Sent from my Nexus 5X using Tapatalk
I'd be more worried of a rusted frame than brittle plastic.
Fwiw, mine came from Tx (I'm in La) and the plastic is fine. No issues.
Agreed and same here, the plastic may have faded on the outside, but isn't brittle.
The plastic wire loom on the engine is going to be brittle no matter where your truck came from. It's science.
I bought mine a year ago with 142k and it had great maint. history, yet I still had to do all of the above maintenance. So solid paper trail doesn't ensure things won't break or need changed. I wish I would have waited and bought a higher-mileage one since I would have done same maintenance and still paid less than what I did. Don't be afraid of the mileage if it is a rig you plan to keep. There is a 4runner locally with almost 700k miles and it's at the dealership. They last forever.
I was in the same boat about 6 months ago trying to go cheap on what is, quite frankly, a toy. Typically the lower miles, the better but look for history, especially maintenance history. I bought mine with 236K and am completely happy with it.
In the end it is somewhat of a gamble but we are talking about a 15-20 yr old truck, it will have some issues that need to be fixed.
I just bought mine at 239k, haven't done much other than change the oil and am driving it to work 2-3 days a week. It needs some things but nothing that isn't normal maintenance.
Basically that's why I got it, to rack up miles on and save my newer vehicle for a longer life of adventures. It's a solid little 4x4 for under $5k, got it to do fill in duty but I'll have fun with it as well.
I'm making plans and collecting parts to do all the maintenance items mentioned here, but it's running good now and I think it would be worse on it to sit while I get prepared than run it until I can do those things. Sitting unused is hard on vehicles, causes things to collect moisture, start to rust, seize up, and stop working.
Not to say it won't all fall apart tomorrow, but as of now, I say if your not afraid of doing your own mechanic work, don't be afraid of them well into the 200k range if it appears to have been treated well and no signs of any major failures imminent (engine running poorly, transmission issues, electrical weirdness, etc...)
That said in my search I found a 98 4runner that had all the boxes checked if you went by the book and looked at CARFAX and general operation. It was low miles, stuff like the timing belt and axle bearings were replaced, sounded ready to go. However, the frame was about to fall out from under it it rusted so bad, and if you didn't crawl under it and have a look see you would have never suspected it.
So records and numbers don't mean jack if you can't assess the condition of the vehicle as it sits. I passed on one with well under 200k for one that was in much better condition at well over 200k.
I purchased my gen3 from a Toyota dealership with 260k on it. They had provided a carfax report and fortunately it had records from all Toyota dealerships it had been serviced in. Best part was that for the first 100k it was a company vehicle and had all records that were non dealership.
2 1/2 years later and I'm about ready to roll 309k and it's still running like a champ. Regular care and feeding will keep it running for at least another 200k. I've only had to put belts and a fan clutch in it. Did the pump and t-stat while the covers are off for the belts.
I take this thing everywhere. Vegas and back from Washington state. I volunteer for rallys in WA,OR,ID and Canada. Hauls all for of our dogs. Tows our Porsche. This thing has done it all.
Get one with good care and you won't be sorry.
I bought my '99 4WD in December 2015 in Minot, ND with 154,000 miles for $4500. It had some minor issues that were easily correctible. I am very happy with it. The timing belt and all the hoses, belts had just been changed.
or
-LBJs
-timing belt
-all fluids
-radiator
-wheel bearings
ETC
And, may I add: Most vehicles will need new tires, shocks, and springs.
Mike Sargent
