fast325it
Hi All,
I have been chasing a darting front end for years now on my 2006 LTD V8. It has 220,000 and runs great. After both Moog lower ball joints failed in under 10,000 miles I decided to replace EVERYTHING and had a competent repair facility install new OEM lower control arms, new SPC adjustable upper control arms, new camber & caster alignment bolts along with the bolt bushings and adjustment plates. Last year I replaced the steering box bushings, shocks (Gabriel OEM style) and tie rods. With the exception of the SPC upper control arms and FJ springs everything is OEM Toyota.
I thought I was well on my way to having a like new front end again. However, the shop could not get the caster right. Even after maxing out the SPC adjustment on the driver's side the attached pic of the alignment shows the caster specs still WAY OUT of spec. He matched the passenger side caster to make it drive "better". UGH, I still have a darty truck!! And, the tires now rub the rear of the fender liner when the steering is turned hard left or hard right. The tech said the frame is likely bent but, I've never hit anything or jumped or been in an accident and I've owned it since new.
Is this an incompetent alignment tech or do you think I have something else going on here? The truck is in awesome shape and I fully expect it to go another 100,000 miles. Before I address the timing belt and components again I'd really like to figure out what's going on with the front end. It's not easy to drive!!
Any thoughts?? PLEASE HELP!
TIA!!
-John
TIA!!
-John
