5100, Toytec BOSS or Icon with FJ springs
Brian3676
5100, Toytec BOSS, Radflo or Icon with FJ springs
I got some free FJ trailteams suspension from a friend that has under 50 miles on it. It's the front springs/shocks and the rear springs, but no shocks. The shop kept them.
I intend to upgrade to a full lift kit in the future, but it will be a while. Since I need rear shocks I am deciding what to go with. I know everyone seems to run 5100 with the FJ springs, but since I intend to get a real lift someday, should I just get Toytec BOSS, Radflo or Icon rear shocks now?
I dont know how it will ride with the FJ springs, anyone have a set up like this?
I've had the FJ spring/5100 setup (1.75 setting on front, 1.5" spacer in the rear, 2.5" lift overall) on my 4th gen for the last 90k. In my opinion, the FJ coils are a pretty good improvement over the 4th gen coils alone. Not to mention the 5100s are a much better shock than OEM. Honestly, it's a pretty good budget setup and I have had my 4runner all over the southwest with no problems. However, I run Icons on my 5th gen and there is a pretty big difference when you get to that level.
I think I am leaning toward the Icons in the rear. Seems to be a tried and trusted shock. Then someday I will get the Icon front coils to match. I know the 5100s are also very tested with the FJ springs, but I hate buying stuff twice and can afford the Icon rears right now.
If it were me I would go with the bilsteins as they would match the quality of the the front set a little more. Yes rear icons would be better but if/when you go to upgrade the fronts to a matching icon setup now you have older rear shocks vs new icons when you upgrade.
What did you end up replacing them with?
5100. I'm much happier with the ride quality and they're holding up very well. I couldn't get used to the digressive valving in the Icons - when they started leaking badly I had a reason to replace them.
Jhunt
