5th gen 4runner build for road tripping?
I know it's a bit dumb but my wife and I always name our vehicles. We decided to name the 4Runner Maximus.
She made this for me tonight, I think it's pretty bad ass!
With the water crossing picture you posted you've likely already put your truck through tougher conditions than 99% of all existing 5th gen LE's out there.
Hey [MENTION=65614]Antman[/MENTION] and [MENTION=112177]4RnR Grl[/MENTION] check out what he named his truck!!! (OP you had to be there...)
I'm really interested to see where this build will go.
I have put 5% tint over all the back windows. I considered putting it on the moon roof, but then I figured if it was too much, I could always just close it. I love the dark tint! Being in the heat of Texas, the dark windows make cooling the car down so much easier.
I actually have a trail and went with a BFG AT in a stock size, but in a load range C. I'm averaging 18.2 mpg according to the computer as of right now. I don't go off road that much, but that I have such great luck with these tires. I've never had a flat with them, they handle snow and ice very well. Overall, great tires!
The other thing that has served me well is swapping out the stock battery for an Odyssey battery. It was a direct fit and I think the stock Toyota battery could possibly be the worse battery ever. Being a traditional wet cell battery they have corrosive issues.
One thing I'm also curious about, what about a weather radio of some kind? Understanding where you have been traveling, storms can pop up, and understanding what you are driving into would have its advantages.
Really looking forward to where this is going!
Swapping the battery is a good idea, thank you!!!
I'm planning on getting a CB that has weather radio reception. That combined with the weather apps I have on my Phone and Ipad should keep us informed. I have a weather app on my phone that will notify of alerts based on current location. That plus the stellar Radarscope app pretty much covers my weather monitoring.
These are the upgrades / mods I'm looking at doing in the next few months
Weathertech mats (Done)
Salex Console Organizer (Done)
Rigid Tool Boxes for Cargo Area Organization (Done)
Canvasback Cargo Liner (Done)
Blue Ridge Overland Visor Organizer (Done)
Escort Radar Detector Remote Cord (Done)
Ram Mount X-Grip with Suction Cup Mount (Upcoming)
Ceramic Window Tinting (Scheduled)
Interior LED replacement (researching)
Under consideration to do in the future
Windshield Wipers (researching)
Headlight replacement (researching)
Bluetooth OBD2 Adapter (researching)
CB Radio (Cobra 75, researching antenna options)
Cell Phone Booster (researching the Wilson Booster)
Dash Cam (99% sure I'm going with the BlackVue 650 Dual Channel)
GoPro Hero 4 Silver (for recording road trip footage)
Additional USB outlet on left side of dash in open switch spot (to power phone)
New wheels and tires (Longer term)
OBD II Adapter is really going to depend on your smartphone. If Apple/IOS, your choices are limited. Probably going to need a wifi enabled dongle. If Android, you can decide cheap or expensive? Bluetooth or wifi? I have an expensive Bluetooth Scantool dongle for Android. I paid for Torque Pro app. The more expensive dongle is more universal. I can plug it into a larger variety of vehicles.
Wilson Electronics cellphone boosters are really cool tech. I have more than one of their boosters. Boosters are not magic. There has to be a little bit of signal to boost. If there is no signal the booster will get you back to signal way sooner than without it. Recommend an All 4g unit. You may find friends/family in need with a different provider than you. Lets say you have Verizon. The Verizon 4g booster works on all 1x, 3g and Verizon 4g. It would not really work well on Sprint 4g. The booster works on dumb phones, Mifi's, Android and Apple. Apple phones see 1-2 db less signal gain than average Android. Motorola phones average 1-2db better signal increase than most manufacturers.
Expect the Sleek booster to average 18db signal increase. I have a Pro model. It's capable of 4 devices. Advertised at 50db signal increase. I average 35db signal gain per device. Proximity to the internal antenna makes all the difference. We also use the app Waze for traffic and speed traps. Never use the signal bars on your phone as a point of reference. Only use the real signal level. Measured in negative numbers. The bars of service on your phone are not always accurate. The real signal level is important when checking signal with/without booster. Using the booster in a high signal environment can slow your data speed. Booster works best in moderate and low signal areas. I have found the middle of a vehicle hood as a great location for the antenna. The normally included 4" rubber antenna is usually perfect. The 4" rubber antenna is typically signal neutral. It doesn't hurt or help 1x, 3g and 4g. Upgraded antennas can help one very specific signal, say 4g. The same upgraded antenna would hurt 1x and 3g.
Wilson Electronics changed their name to Weboost. This also increased their prices.
Scantool for Android
All 4g Sleek
Big Booster, not the cheapest option
Thank you for the recommendation on the Indel. I will check them out.
Do you know if there is a US distributor?
Look at the portable models to the right. Those are Indel B fridges.
I have the 41 liter. Fits perfectly under the cargo cover and can be shipped to your house for $544.
TruckFridge.com - Quality true 12 volt DC compressor refrigeration with freezer - Georgetown, KY Exit 129 next to Piolt Truck Center - many models to choose from.
Tigger's Indel B Fridge
Thanks for mentioning this. What model of battery did you install? Was it the Extreme - 34-PC1500T? I think I'm going to get an Odyssey when the stock one needs to be replaced (if not before).
Someone mentioned the MDX. Avoid the 9spd transmission. The same transmission has the potential of an Acura class action lawsuit. The same 9spd is really horrible in the 2014+ Jeep Cherokee. The high end Honda Pilot now has the 9spd transmission. Check the user feedback. It's not favorable. However, the lower trim Honda Pilots come with the much better 6spd transmission.
I used the Odyssey 34R-PC1500T. Since it has the reversed poles it fits really well. Its been a great battery! I can't say enough good about it.
We bought the small ARB fridge used. It's very handy. I paid $400 used. I placed blue ice at the bottom of the fridge (freezer section). When I unplug/turn off the fridge the blue ice helps maintain low temps overnight until we start up again in the morning.
Ram Mount X-Grip with Suction Cup Mount (Ordered)
As for your CB radio antenna, I went with a 3ft Firestik, but will be downgrading to a 2ft after our cross country trip next month, and a Diamond k400 antenna mount. It's the sleekest mount I could find and I love it. Looks awesome. You can also adjust it so it's not as high, but I prefer it where it is, less interference.
Diamond k400 Antenna Mount
image_zpsvufoqimb.jpeg~original
image_zpslncy8sx8.jpeg~original
With a mount and antenna like this, how much flex in the antenna is there? If you are going through a drive thru or under any low clearance area how does it handle impacts?
Do you need to install a mount spring?
I usually take mine off if I'm afraid it's going to hit, but you can install a spring on the bottom so if it does, it'll just bend. I chose to just put on a quick disconnect so I can easily take it off before a drive thru or parking garage rather than hoping it doesn't bend more than it can. I have had no problems and the one time I did forget in a drive thru, it was fine :)
CB Antenna Spring
CB Antenna Quick Disconnect
CB Antenna Spring
Thank you for this info...perfect for what I am looking to do.
Depending on how far afield you go, I'd bring a spot, or my favorite,the DeLorme inreach. This gives me text, sos and when paired with my iPad, fantastic off road map capabilities. My girlfriend and I plan on heading up yo Labrador this summer from NYC on a mostly dirt road trip. This build thread has some really great ideas it it, let's keep them coming!
Update:
We're headed out to New Orleans in less than 3 weeks, this will be the first trip in the 4Runner. I've decided to take the advice of several on here and get a couple of trips under our belts before we do make any real changes.
I've added a couple of new things in the past week, RAM Mount for my phone and Escort Radar detector with remote mute.
I'll talk about the RAM Mount first.
I purchased the RAM Suction Cup Mount with the X-Grip Large mount. The link to what I got is here. Amazon.com: RAM Mounts (RAM-B-166-UN10U) Twist Lock Suction Cup Mount with Universal X-Grip Iv Large Phone/Phablet Holder: Cell Phones & Accessories
I also ordered a RAM Double Socket Swivel Arm for 1 Inch Bases - Amazon.com: Ram Mount Double Socket Swivel Arm for 1-Inch Ball Bases: Automotive
This is my first purchase from RAM and I am very impressed with their products. In the past, I've always bought Bracketron phone mounts and while they function, I haven't ever really liked them. To me, the Bracketron's are "flimsy" feeling. But the thing I really didn't like, was that the mount partially obscured my view out the lower left of the window. It wasn't so bad as to be dangerous, but it was annoying.
My goal with the RAM was to position my phone so that it aligned with the pillar and didn't obstruct my view. This is why I purchased the Double socket Arm.
I cleaned off the top left corner of the window with 99% rubbing alcohol, warmed up the glass with the defroster and stuck the suction cup as high and tight into the corner as I could. The twist lock mechanism is very solid and the suction cup stuck to the window like a breastfeeding newborn.
I then mounted the X-Grip holder into the Double Socket Arm and loosened all of the adjustments until they moved freely. I attached it to the ball joint of the suction mount and tightened it enough to not fall off but still be moveable.
I tried out a lot of different positions until I found the one I liked the best. I was able to accomplish my goal of putting the phone in line with the pillar from a viewpoint perspective. With the suction cup at the top corner of the window, the arm does not interfere with the view of the driver.
Once I got everything placed and tightened down I was really impressed with how solid the whole thing felt. There is no flimsiness to this phone mount.
The XGrip holder works great, it holds the phone tightly with no chance of it coming loose. The charging port and Ear Bud connection are both exposed and easy to access.
We'll see how it does on the upcoming trip, but so far I really like it.
What it looks like from the passenger seat
Close up from the passenger view
View from slightly behind the driver position, the mount lines up with the pillar when viewed from the driver seat
From the left side
From outside - strange dash color in the light from the flash
I also got my Escort Radar Detector mounted with the Remote Cord placed on the dash down by my right knee.
I've been using Escort Radar Detectors for over 20 years and I love them. They have saved me from 1000's of dollars worth of tickets and kept my insurance rates low. The model I have in both our vehicles is
http://www.amazon.com/Escort-Passport-8500X50-Detector-Display/dp/B005IQGNCU/ref=sr_1_6?s=electronics&ie=UTF8&qid=1458365363&sr=1-6&keywords=escort+radar+detector
I mounted the detector in the upper center of the windshield behind the rear view mirror. The display is just slightly below the bottom of the mirror so I can see it. I believe this is the optimum mounting point for two reasons:
1) It is not obvious when looking at the windshield. With the remote cord which goes up and into the headliner, there are no visible wires to draw the eye.
2) You get better reception with it higher on the vehicle.
I used the following remote cord from Escort.
http://www.amazon.com/Escort-Direct-Wire-SmartCord-Light/dp/B0003NN83K/ref=pd_sim_107_2?ie=UTF8&dpID=41LHvDzNG-L&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=0FWE5RBFYVY8RHG86PQK
I had the button placed by my right knee where the vertical part of the center console intersects the lower dashboard.
By placing it here it is not visible when standing outside the vehicle, and it's easy to reach down and hit the button without any other motion than a slight arm movement.
The detector mounted behind the mirror.
The remote mute button mounted on the lower dash
I have a GoPro Hero 4 Silver on order that will be in early next week. The plan is to mount it as a dash cam for our trip to New Orleans. I am going to experiment with it mounted both inside and outside the vehicle. I'll make an update post when I install it.
I'm really happy with the 4Runner so far, can't wait to try it out on a road trip.
I look forward to hearing how your road trips go and the lessons you learn along the way.
the safety engineer in me is curious if you have concern with installing/ mounting all that crap in front of your upper torso (neck, head, face)? In the event of an accident seems like you'll have a lot of ammunition coming into your head and face... smartphones, pens and whatever else you have in that visor organizer...
lastly, once a year my wife and I take a long road trip over the holidays when we both have extended breaks from work... here is a summary of our
2014/2015 trip: http://www.toyota-4runner.org/4th-g...u-do-your-4runner-today-1083.html#post1887214
2015/2016 trip was around the SE USA but I haven't done a summary writeup yet for...
This is merely an observation so forgive me for suggesting as I may be way off, but you've placed the RAM mount directly in the path of one of your airbags. My thinking is that you've turned the RAM mount into a missile directed right at you where instead of the airbag saving your life, its now simply a cannon with a loaded barrel. Again, not trying to be an ass or confrontational, just wondering if its a factor or not.
EDIT* Not trying to copy Nuclear N8, I was typing my response at same time evidently. But at least I'm not alone in the observation....
Nuclear & Rover, I appreciate your feedback and yes, that has definitely gone through my mind.
Before I mounted the RAM, I did some research on exactly where the airbags deploy from. On the IIHS website there is video posted of a small overlap front end collision. The slow motion version of it clearly shows the deployment of the airbags. http://www.iihs.org/iihs/ratings/vehicle/v/toyota/4runner-4-door-suv
Based on what I saw in those videos, I THINK I have the RAM mounted in such a way that it won't be in the path of the airbags. I know it is behind the steering wheel and I think I have it spaced far enough from the driver side window that it wouldn't be caught in the airbag.
Have they added a new airbag since it was tested?
Even if it doesn't get propelled by the airbags, it certainly still presents a potential danger just by coming loose in an impact.
As to the visor, I have already relocated a couple of items from it to the center console.
Jhunt
