5th Gen 4Runner Dash Plate
RagoFabrication
The Toyota 5th Gen 4Runner Modular Dash Mount was designed to add amazing versatility to your 4Runner's interior. This product was designed to be low profile and blend in seamlessly with the factory design while still utilizing the clock. This mount allows you to attach multiple accessories to customize your overlanding needs. The Dash Mount is equipped with 11 10-24 Self Clinching Nuts which gives you various ways to mount your equipment! Each Mount will include 2 Adjustable Accessory Mounts for both the Driver and Passenger side so you can attach a Ham Radio or any magnetic mount for your devices.
https://www.youtube.com/watch?v=6rMNYZE84tE
Ordered!!!
Is it still easy to see the accessory display behind this? Really curious about the display on a 2014 Trail that has all the extra info like mpg, range, compass, and clock.
Not a good price point for me. I can't see paying $95 for this. Maybe if it was under $75. Sorry. I've purchased most of your other 4runner products and I'll have to pass on this one.
That corner welds is keeping me from getting this.
How about if you design the corner cuts to overlap it and either don't weld it or weld it on the inside to have it out of sight... it seams (from the pics) the steel is thick enough to provide rigidity without the weld
Any issues if airbags deploy? This looks cool and would buy, but wondering if there are safety concerns
I can't think of anything in that area that is an airbag issue, other than possibly having something mounted off the side? But that would be an issue if you mount anything in any way off the center area.
I'm not the rep for Rago, just voicing my own opinion. There's more stuff mounted in most of the police vehicles in my fleet than this, and their airbags work just fine. Don't cover the center of the bag where it deploys, you should be good!
I really like this one!
I have an ICS which is also awesome but probably would have gone with the Rago mount had it been available last year
I think the price point is just fine. Take a look at their competition, I believe they are the lowest of the three that I know of.
They said you can still see the clock. However I'm a little skeptical of that. If you're directly in front sure but with their design you're likely going to have to duck your head down a bit to even see the clock. Depending on how tall you are I see this thing completely covering the clock display.
That's exactly what I was thinking. You're going to be looking down and to the right so it'll probably make that display useless. Just like the other options on the market.
I have the ICS fab one and I can still see the clock for the most part. A tiny fraction of the upper part of the first number get clipped a bit but I can always tell the time and the rest is visible. I am however only 5'7" so it's probably worse for taller people. I think of all of them the ICS fab is the least offensive and I doubt you can see anything on the Rago one. The EOE well that is a no.
Good to know. I have no need for this as I've gone with another solution before these mounts were around, but they look cool and functional for sure.
