RCI KDSS Aluminum skid plate 4runner sale 200.00
RCI Aluminum front KDSS skid plate.
No longer need this one. Noththing wrong, no cracks. It does have a few small scrapes. ( see pics)
It was painted black, but i stripped it back to Aluminum.
Has hardware.
email with any questions.
[email protected]
Located in Indy, IN. will ship.
URD Underdog racing development MAF Calibrator. 125.00
No longer need this. Plug and play. works perfectly
This version of the famous URD MAF Sensor Calibrator is now PLUG-N-PLAY for super-fast installation. No cutting and splicing. Takes about ONE minute to install and remove without leaving a trace. The unit has OEM connectors installed for a very fast, simple plugin installation.
Applications
2010+ Toyota 4Runner with 4.0L V6 engine
We have maps we can preload for normally aspirated applications with the following intakes:
2010+ Toyota 4Runner V6 with aFe Stage 2si intake
2010+ Toyota 4Runner V6 with Stock Intake
2010+ Toyota 4Runner V6 with TRD Intake
2010+ Toyota 4Runner V6 with Volant Intake part number 18840
2010+ Toyota 4Runner V6 with aFe Momentum GT Intake
More applications coming fast!!
If you have a 2010+ Toyota 4Runner V6 and you do not see your combination listed and are closed to URD in Owings Maryland, contact us about getting a free custom tune!!
Tuning software is available free of charge so you can do your own custom tuning if you have a combination we do not have a map for.
Have you been looking for a cost-effective way to tap into some of that hidden power? Have you been looking for a way to get that expensive cat-back exhaust system to live up to your expectations? Has your expensive aftermarket air intake system let you down? You need the ability to retune your ECU for these aftermarket upgrades to get the performance gains you expect.
The URD MAF Sensor Calibration Unit allows fuel curve re-tuning to find that hidden power you are looking for. The URD MAF Sensor Calibrator and your tuning will tie all of your performance modifications together, unleashing all the power available from them.
The URD MAF Sensor Calibrator is basically the fuel control half of our very successful URD MAF/Timing Calibrator that URD included in our Supercharger Performance Upgrade Kits for years. We know that not everyone needs timing control, and removing the timing control function saves you a lot of money.
The URD MAF Sensor Calibrator intercepts the signal from the Mass Airflow Sensor and remaps it optimizing the fuel mixture for the best power and performance. It is the ability to retune that optimizes your modifications allowing them to work together as they should.
It is programmed using included tuning software based on manifold pressure or throttle position (depending on the version) and RPM. The software has more resolution than any other end-user fuel computer in this price range. You will need a Window PC and a serial port or USB to serial adapter to connect to the unit for tuning.
We offer two basic URD MAF Sensor Calibrator versions. One is primarily for normally aspirated vehicles that use the signal from the throttle position sensor as the load scale indicator and one with a Manifold Absolute Pressure Sensor (MAP Sensor). The unit with the MAP sensor senses the manifold pressure and is primarily for engines that have forced induction.
The unit for normally aspirated engines can be used for:
Optimizing the fuel mixture for best power on stock or modified engines
Correcting MAF Sensor error caused by aftermarket intake systems
Remapping the fuel curve to compensate for high flow headers, exhaust systems, and cams
The unit with the MAP sensor for engines with forced induction systems can be used for:
Re-tuning the ECU for larger than stock fuel injectors
Re-tuning for increased boost levels
Here is a typical example of how effective the URD MAF Sensor Calibrator can be. This is a dyno chart from a totally stock 2005 Tacoma X-Runner. As you can see there was a hidden 15 Rear Wheel Horse Power (RWHP) just waiting to be unleashed. Results from totally stock vehicles typically yield 8-15+ RWHP. We even found 15 RWHP on a totally stock Camry.
If you have been considering some other end-user tunable fuel computer for your vehicle we think you will find that most of them have the resolution of a very dull butter knife and cost you much more than our solution.
Our map table is truly three-dimensional and has 61 load columns and 16 RPM rows for a total of 986 map table cells all of which are directly accessible. Each cell has 200 levels of adjustment. There is nothing else out there that is this easy to tune with this level of map resolution in this price range, NOTHING. Only the best from URD.
The units can be used on any 0-5 volt sensor, but are primarily used to re-calibrate the MAF Sensor signals. If you wish to modify some other 0-5 volt circuit based on RPM and TPS/Manifold Pressure the unit can be applied to your needs.
The unit ships with the tuning software and a vehicle-specific connection guide for the vehicles listed below. Just select the vehicle you have and the appropriate guide will be included for you. If you have some other vehicle not listed, the unit will ship with a generic connection guide to assist you in your installation.
Stock seats for sale from 2019 Off-road
Seats are black with red trim and the front seats are heated. If need the top cover of center console with controls for the heated seats I have that available too.
Located in Denver NC near Charlotte.
Each front seat is $300 and the entire back seat $400. Shipping is available if required.
Seat belts are available too if needed.
You can see the front seats in my video just above.
Sent from my Pixel 8 Pro using Tapatalk
I recently sold my 4runner and have some leftover parts that I need to sell.
Heftyfab Windshield washer skid.
- Still brand new in the box that it shipped in
- Not coated
- $70 shipped
These items I will not ship... local pickup only in Denver, Colorado
RCI Aluminum Transfer Case and Transmission skid
- The cross member for the transfer case is not pictured, however it is included
- Brand new hardware from RCI included
- Asking $400 for both, pickup only
Dobinsons IMS Ext Travel Struts w/ C59-302 front springs [SOLD]
Toytec Aluma 2.0 Rear shocks
- Brand new, never installed
- Asking $300 pickup only
DEPO headlights
- Used for a short time while I was retrofitting another set of headlights
- Inside shrouds have been painted black
- Asking $100 pickup
I’ll take the reservoir shipped to 77018
I'm selling an Eezi-Awn brand k9 full length roof rack. It came off of my 2013 Trail edition but will fit any 5th gen. It's an amazing rack made in South Africa and is expedition grade. Fully welded aluminum, It's one piece! It's been extremely solid. No creaks or squeaks and no loose wiggling. They rate it at a 500lb capacity while moving and 1000lb capacity static.
Also included is an Eezi-Awn lite awning. It's the 2500mm size so it's huge! It mounts straight to the rack by way of the Eezi-Awn system.
I'm selling it with a Rhino rack folding ladder, a must to load and unload gear, and awning mounting brackets. Also included are 8 tie downs that slide into the rails to provide extra mounting options.
All hardware included and in place ready for install. This rack is the 49"W x 87"L size they sell and provides full roof coverage.
PRICE DROP
$1,000 local pick up only, Tucson AZ. This things gotta go, its taking up so much space!
NIB 2019-2020 Eibach TRD Pro Lift Kit Springs
Hi guys, I purchased a set of springs for my Pro (SKU: E30-82-071-03-22) but since then I became a Dad and my priorities have changed. The springs are new, in the box and I'm willing to part with them for $300 not including shipping. If you're interested in them, will you lmk? Happy to coordinate a local pickup in New England (I'm in RI). Thanks for looking!
FS: 2016 SR5 Primuim
2016 Toyota SR5 Premium (3rd row)
Our 2016 Toyota SR5 Premium showcases a wide array of modifications and is offered at $34,998
We purchased our 4Runner in 2016, and are the original owners. We have had a lot of fun in this rig, and hate to see it go. It has 91,000 well maintained adult miles. This was a well thought out, and documented build. There isn’t much that hasn’t been done, and there is much more that isn’t listed below. We will include many new spare parts, and most of the OEM take-off’s that were left over from this build (Original 3rd row seats, OEM suspension, Icon bypass shock mount kit, Front bumper, new spare parts: LCA’s, axles, and many other spare misc. parts) I have a lot more pictures as well.
Distinguishing Features
• King remote reservoir coilovers
• Goodyear Wrangler Duratrac 295/70-17LT (34) (new)
• Method wheels
• Power Stop disc brakes (new)
• Dobinsons C59-701 rear springs
• ARB air lockers front and rear
• 4:56 Gears from East Coast Gear Supply
• Icon UCA’s w/ Delta joints
• Custom long-travel rear links
• Total Chaos spindle and frame bracing
• RCI Skids (front and fuel tank)
• Metaltech front bumper with Warn VR1000
• 4X4 Labs rear bumper, with both fuel tank and bike rack options
• Switch Pros SP9100, with room to expand
• Black Oak LED lighting
• Custom roof rack
• ARB twin motor on-board air system
• Dual battery system, Blue Sea components, Optima yellow tops
• ProMariner On-board AGM charging system
• Dobinsons snorkel
• Kenwood KDX694 stereo system with Garmin Nav., JL Audio XD400/4, RF Punch P500X1, Pheonix Gold, custom
Rockford Fosgate 10” sub
• Custom rear drawer system with subwoofer enclosure
• Rago rear cargo racks
• Pedal Commander
• Husky floor Liners
• Most of the OEM take-off parts are included
This 2016 Toyota 4Runner Trail Premium (3rd row) is offered at $34,998 and is currently located in El Dorado Co. CA.
Matt
Selling my lightly used Alpine Halo9 that I had installed in my 5th gen 4Runner. I'm selling it with modified stock metal HU mounts. I had this installed in the lower din and it did not cover the vents at all. The top was literally directly under the AC vents which was a big thing for me. Included are also a brand new stock wiring harness for a 5th gen non-JBL harness, a brand new radio adapter harness, and a brand new Scosche silver dash kit. Radio comes in original box, with all the installation manuals and paperwork.
Radio is great, and has wired Android Auto/Apple Carplay and an HDMI input.
Radio was reset to factory defaults before removed. The radio still has the stock screen protector from the factory.
Here's a picture of the dash kit
Stock radio brackets
Here's a pic of the wiring included, minus the radio harness
Asking $500 for the radio, these are going for $700+ used on Amazon. Buyer would split shipping with me. If you need the radio harness soldered together I'd gladly do it for an additional fee. This is truly plug and play, all you would need is a steering wheel controller since I reused mine with my newer radio
Amazon listing example
Amazon.com
Sale thread
https://www.toyota-4runner.org/for-sale-non-t4r-items/311664-fs-alpine-halo9-ilx-f309-w-5th-gen-install-gear-$500-pittsburgh-pa.html#post3809727
Bump, somebody want this? :madgrin:
Local pickup only. $800.00
Up for sale is a complete stainless steel powder coated roof rack from LFD Offroad. Includes 9 cross bars, cross bar with wind deflector, and all hardware.
Zero rust, well taken care, and touched up anytime a scratch was noticed. Little to zero wind noise!
Traded 4runner for a truck, no longer needed.
Fits all 5th gen 4runner. 2010, 2011, 2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020, 2021, 2022, 2023, and 2024.
See my other listings for my 4runner equipment.
See: Full Roof Rack - 5th Gen 4Runner – LFD Off Road
I am interested, please PM
Thoughts?
Thinking about buying my first T4R — a 2016 SR5 Premium with 145,000 miles. Car is in good shape. I need advice though — The owner has done some work himself, new suspension (Bilstein 5100s), etc. and says he has done all of the maintenance himself which I think is generally great, but no proof to show that. Any thoughts on this?
I got burned on my 2008 tacoma, in Feb 2009, took it to the dealer to get an oil change right before going out of town with the family on a trip. After leaving the dealer i head to my shop to grab a few items before i go load the family up and heard the identical noise as you heard in the original Fast&Furious when the green eclipse motor let go. SAME sound. My engine locked up and i bumped it in neutral and rolled to a stop. 6 miles away from the dealer my motor locked up and a rod cut thru the oil pan and literally only left about an 8oz cup of black oil on the ground. The oil change guy forgot to put the oil in, so i lost a motor.
I got burned on my 2012 4runner, i think it was early 2013, wife took it to the same dealer, to get oil changed the day before she left for her yearly trip west to visit family for Thanksgiving. She got home and parked, i came home later and noticed a huge puddle of oil under the 4runner. Turns out the oil change guy broke the plastic cup for the filter and didnt tell anybody and let my wife go on her way. Of course they didnt have the cover in stock, so the 4runner was down for a week and our second trip ruined from a botched oil change.
That day was the LAST day i have ever taken any of my toyota vehicles to the local dealership. I have not changed the oil there once, not one set of brakes, spark plugs or air filters, i wont let them touch anything. I buy parts from them but i do the work myself or take it to a different shop i have learned to try to trust. The new shop doesnt report on carfax so all of my vehicles past records are a ghost. But i can tell you my Tundra has 550,000+ miles, my tacoma hit 275,000 before i sold it, that 2012 4runner we got rid of around 160,000 miles, my current 2008 4runner has 225,000 on it.
I change the plugs, filters, oil, brakes, wheel bearings, and any other maintenance item as needed but honestly, of all the miles i stay in the road my toyotas have been uber reliable.
Check it out yourself, check the filter and intake behind the filter for dust or dirt. Take a floor jack and jack each front wheel up and spin the wheel and check the wheel bearings. Check the oil, pull a spark plug or two, if he wants to sell it and you want it bad enough you will go over it.
These vehicles are very reliable though, if the maintenance is done.
Have an inspection done at an independent shop. At 145k miles without records it seems like the owner would do his own work if the truck is running still. I do all my own oil changes, filters etc on my cars and keep notes of dates/ mileage and where I purchased material from. Do I keep receipts of the items not really but typically ordered online during sales.
Finally coming back with photos. Here first are my front and rear seats which are all for sale.
Located in Hudson, NC.
Front seats are $300 each and the back seat $400.
Just a little dirty in the photos but on shape as they are out of a 2019 which was only driven 20,000 before I made it a dedicated off-road vehicle.
I did a quote for some and it was $100 to ship a front seat. For sure if combing seats into single shipment shipping would not be double.
Here in this post are the control units from my truck.
I have:
ECU - $100
Air bag sensor hub - $30
MPX Body controller $80
Flasher module - $25
4 Wheel Drive Control $75
Tire pressure monitor - $20
All located in Hudson,NC and shipping not included but should be inexpensive since these are all small.
We're removed as stated above from my 2019 with very low miles.
The Velcro on the ECU was from my UCON controller for the Whipple supercharger.
Now here we have interior panels:
Dash -$300
Glove box -$80
Drivers side panel under steering wheel -$50
Small panel on driver's side -$30
Sold - Steering Wheel -$100 Sold
Steering column $125
Kick panels from both sides - $20 each
Vertical trim from center console - $25 each
Additional photo below shows a box with other parts like speaker cover, vents, etc, this is all available too.
Shipping not included but available. Everything is located in Hudson, NC.
Here's the speedometer and panel which goes immediately below it crash bar or whatever it's called which goes behind the dash and a seat belts.
Seat belts -$75 each have all four
Speedometer $150
Dash bar -$50
Rear seat reclining track - $20 each
premiumusedautoparts
