Scowling Tuna
BUMP
$575, Never used off-road.
bump, $550
Edit: Shrockworks sliders, gonna' have to scroll up to see more info, sorry
BUMP
FS: Custom Rear Platform with ARB Fridge Slide for 4Runners with Factory Rear Sliding Tray - $300
What it is: A custom metal frame that bolts to factory tie down holes - 1/4" plywood secured to the frame, upholstered in black carpet, ARB Fridge Slide Bolted to Plywood. This allows rear slide out tray to remain in place and functional as an additional little shelf.
Where it is: Arlington, VA - pickup only
This was installed in a 2010 5th Gen - I assume stuff is the same throughout model years since this generation is a dinosaur but who knows?
Selling my Accessorides Plug and Play Remote Start kit for 2011-2019 4Runners with push-button start. Works perfect like the factory remote start. Install is simple, under an hour.
$120 + shipping.
bump
bump
$575, never used off-road.
*added photosFor Sale - Set of stock Off Road Premium rims from a 2021 4runner, with stock tires, valve stems but no TPMS sensors.
Asking for $500 local pickup only. They're still bagged up but I'll get photos shortly.
*Bump still for sale*$1,100 FIRM*
SAN DIEGO, CA
I’m selling my BRAND NEW Shrockworks 2010-2013 front bumper with full hoop, comes with new lights and wiring for the fog lights, and washer skid plate. Bumper was taken off the wooden crate and has been sitting in my garage protected for the past 8 months. No longer wish to put this bumper on my vehicle. Save over $700 on this bumper and half a year of waiting. Located in San Diego, CA ... willing to deliver in the LA/SD area, if you are not local, expect a pickup (Will not ship).
Specs:
Key Bumper features:
• Powder coated
• Skid plate for the washer bottle reservoir on the passenger side. This thing hangs really low and need to be covered for both protection and aesthetics. You get both standard with the ShrockWorks 5th gen 4Runner front bumper.
• 3/16" aluminum front skid plate included standard.
• Two Recovery Points. They are a FULL 1.0" thick and are welded front and rear. They accept 3/4" clevis shackles and the width prevents them from flopping around.
• Accepts FACTORY Toyota fog lights. The ones that you probably already have.
• New 2.5" round turn signals and wiring included. (2010-2013 year models)
• Optimized for off road performance with greatly improved approach angles.
• Hidden winch mount accommodates most non-integrated solenoid winches up to 9500 lbs.
• Driving light mounting holes on top of the bumper.
• Extremely stiff wraparound wings resist flexing into the body.
• Looks great with or without a winch installed. No gaping empty hole where the winch would be. A license plate will cover the winch opening if you are not running a winch keeping a clean appearance. License plate mounting holes are included.
• Designed with clearance in mind for larger tire upgrades.
• Installation is a simple bolt on.
Quick Specs: - 3/16" plate steel bumper
- 3/16" steel body & skids.
- 1/4" mounting brackets
- 1.0" thick plate steel recovery points
- All new hardware included
- Finished in a 3 stage show quality, super durable powder coat. No thin, peeling off stuff here.
- 137 lbs
Pics for reference from online source:
For sale - Slide out cargo tray. Local pickup only in the Minneapolis, MN area. Asking $300.
Recently taken out of my 2013 TE. In good condition. Comes with everything - Hardware, carpet, covers, transition piece, brackets, etc.
If your 4runner did not come with a sliding tray from factory, the mounting points are there but need to be exposed. More info below.
https://www.toyota-4runner.org/5th-...C2M6Mf7vZeVOL3axH6okNRjtzvGvh6eJuJnnqi-vL5EnE
I can get better photos if needed.
Changing up my lighting so im selling a Pair of CaliRaisedLed amber Ditch light pods with harness
doesnt include dash switch or bracket
used for only about 5 months
$100 plus shipping or local pickup
If you change your mind about shipping, let me know.
