Additional Photo
Front, rear, and sides.
*SOLD*
Updated listing 2015 Trail
SOLD
2015 Toyota 4Runner Trail Premium, 98,xxx miles
Two owner vehicle. I purchased it from a dealer with 20,xxx miles in 2016. Barcelona red with black and red Softex interior. Non-KDSS. Airlift 1000 airbags in the rear, Fumoto oil change valve, Toyota metal oil filter canister, Kicker speakers throughout, Kicker Key amplifier. Oil, transfer case fluid, diff fluid recently changed. New battery and air filter. Transfer case front and rear seals replaced at approximately 90,xxx miles. Coolant and serpentine belt replaced at approximately 90,xxx. Includes NiseRack roof rack. Recently detailed inside and out. Located in Central Ohio. I'll attach pics once it gets detailed this week :thumb3:
Listing - Autotrader - page unavailable
Asking $27,500.
5th Gen Aluminum Roof Rack Using OEM Siderails: NiseRack
Eezi Awn full length roof rack $500 Tucson, AZ
I'm selling an Eezi-Awn brand k9 full length roof rack. It came off of my 2013 Trail edition but will fit any 5th gen. It's an amazing rack made in South Africa and is expedition grade. Fully welded aluminum, It's one piece! It's been extremely solid. No creaks or squeaks and no loose wiggling. They rate it at a 500lb capacity while moving and 1000lb capacity static.
I'm selling it with a Rhino rack folding ladder, a must to load and unload gear, and awning mounting brackets. Also included are 8 tie downs that slide into the rails to provide extra mounting options.
All hardware included and in place ready for install. This rack is the 49"W x 87"L size they sell and provides full roof coverage.
PRICE DROP
$500 OBO local pick up only, Tucson AZ. This things gotta go, its taking up so much space!
Remote Start
5th Gen plug and play remote start from Accessorides. Easy install, works with push-to-start only via factory fob. I know works up to 2018, not 100% sure about newer models.
$75 shipped
378955d1616162976-5th-gen-sale-wanted-thread-img_0575-jpg
$75 shipped
By any chance would you know happen to know if this can be used concurrently with the Sprint Booster? I can’t recall which port that plugs in to…
X20 10K Winch
Selling a Smittybilt X20 10k Winch. Original synthetic line and an Agency6 flat link.
In good working condition.
$360
SOLD
OEM Suspension Parts plus Set of 2” Lift Springs
All original OEM suspension parts taken off a 2018 TRD Offroad at 8,000 miles. Front struts, upper control arms, rear springs, shocks, upper and lower links, and track bar. Also included is a set of Metal Tech 2” lift springs with the heavy spring rate. The 2” lift springs had about 10,000 miles on them before being swapped out with a set of Dobinson 3” springs.
Located in Phoenix. Asking $400 obo. Local pickup preferred.
Converted my SR5 to a trail
All parts are from an SR5. Would like to sell as a deal:
Hood, side skirts, front bumper, roof rails, all associated plastic pieces that are behind the front bumper and in front of radiator, mud flaps(not oem). Front hitch that is specific for the SR5. Headlight assemblies, all the fender flares. I am sure there are a couple of other items.
Color SALSA RED PEARL, 3Q3.
The hood has a couple of clear coats spots peeling, probably 2.5 inch x 2.5.
I am located in Ma near the south shore.
I might meet within a reasonable distance for serious buyers. Make a reasonable offer.
Here are before and after pictures.
Non scoop hood for sale
Red non scoop hood for sale no dents
Location is in Massachusetts
Make reasonable offer
If you are close I might meet halfway
Thank you
Depo Smoked Tail Lights BNIB, Morimoto XB LED Fog Lights, Lasfit 921 LED Reverse Bulb
Selling some parts, the first is a brand new set of Depo Smoked Tail Lights
The driver's side was installed by a body shop, and removed a week later since I had a different set of LED tails that I wanted to install. These are brand new and sell for $290+tax on Amazon. Asking $200 shipped for the pair.
I also have a used set of Morimoto XB LED Fog Lights. These are a straight drop in replacement for the OEM fogs and are blacked out housings. One tab was damaged in my fender bender so the body shop replaced the entire set. I repaired the damaged tab with plastic weld and it's good as new. These retail for $175+tax/shipping so I'm asking for $100 shipped for these.
Repaired tab
Also selling a pair of Lasfit LED reverse lights, these are some of the brightest reverse lights available and they look great. Asking $20 shipped for the pair.
And finally, selling a brand new Steering Wheel Angle Sensor, I ended up with an extra one and have no use for it. It's brand new and never been installed. These retail for $80-100, so I'm asking $50 shipped.
2010-2013 radio
Hello all, I am looking for a non jbl touch screen preferably without nav. I am located in Massachusetts zip code 02346 for shipping
MMJR_T4R
