5th Gen Metal Fab Options and Considerations
enginerd4ni
Member
In an effort to explore the various aftermarket upgrade options for my 5th gen, I put together this list of common metal fab parts relevant to wheeling/overlanding. This hopefully will help some as a starting point for doing research as they figure out how they want to outfit their rig to meet whatever goals they are trying to achieve. My goals for my rig are centered around medium overlanding capabilities with daily commuter practicality.
I have intentionally left off anything about tires/wheels/suspension/CB radio/lighting/camping gear/compressors/winches/etc. since there are far too many options to list.
I have likely missed several obvious suppliers so please PM me and I'll add them to the list.
Sliders / Rock Rails
Things to consider:
-Not all kits are instantly compatible with SR5/Limited and may require trimming or replacing panels or other modifications
-HREW vs. DOM
-Mounting method: frame weld nut bolted, frame U-bolted, frame welded, frame drilled and bolted, body/rocker bolted
-Protecting the frame vs. rocker panels vs. door panels (bump outs)
-Compatibility with KDSS
4x4 Labs Example Thread
BAMF $290 to $575
Bud Built $467 to $919 Example
Demello $350 to $699
Metal Tech 4x4 $450 to $650
Randy Ellis Design $490 to $610
Rocky Road $339 to $439
Shrockworks $456 to $814
Slee $945
White Knuckle Offroad $460 to $720
Front Winch Bumper
Things to consider:
-Winch size and solenoid location restrictions
-Lighting options built-in and add-on
-Recovery points
-Airbag sensor sensitivity to light impacts while wheeling
-Protection or relocation of washer fluid reservoir
-Overall weight and impact to suspension
-License plate mounting if required
-Approach angle and integration with skid plates
ARB ~$1238
Bud Built Winch Bumper $1250 to $1485 Example Thread Bud Built Hidden Winch Mount $375 Example
CBI
Fernando's Build (just because it looks really good)
Rocktek $1275 to $1545 Example Thread
Shrockworks $1267 to $1429
Southern Style Speed Slimline for 2014+ Example Thread
Rear Bumper
Things to consider:
-Hitch design, weight rating, removability
-Swing out accessories like tire carrier, jerrycan, hi-lift mounts
-Departure angle
-Relocating and/or interference with back up camera/sensors, license plate
-Compatibility with roof ladder
-Bumper trim differences between Trail/SR5/Limited, permanent cutting vs. return to stock
-Cutting the cross member vs. bolting to it
Bud Built $1100 to $1935 Example Thread
CBI $1000 to $1575 Example Thread
Fernando's Build
Hefty Fabworks Example Thread
Seabee's Tire Carrier Example Thread
Shrockworks $2165 to $2589 Example Thread
Roof Rack
Things to consider:
-Overall vehicle height (will it fit in your garage with your current or future lift?)
-Full length, standard length, or basket style
-Mounting points, brackets, methods (especially for full length)
-Dynamic and static weight rating
-Availability and ease of installation/use of accessories and attachments like hi-lift, jerrycan, rtt/awning, lighting, kayak
-Compatibility with the XM antenna bulge
-Center of gravity including what you put up there with respect to highway vs. off highway speeds and dynamics
-Compatibility with a ladder
-Durability, UV resistance, and type of paint
ARB $660 to $1029
Baja $795 to $999
drabbits $749 to $896
Eezi-Awn Example Thread/Equipt
Front Runner $848
Garvin Wilderness Racks
Gobi $1495
Rocky Road
Skid Plates
Things to consider:
-Weight gain and impact to suspension and vehicle dynamics
-Material (aluminum vs. steel) and corrosion resisting finishing options (powder coat vs. rattle can vs. bed liner etc.)
-Ease of access to oil filter and drain plug
-Quality and corrosion resistance of mounting hardware
-Integration with other parts (sliders and winch bumpers)
-Front (engine cradle), Mid (engine/oil pan), Rear (Transmission/transfer), Gas Tank, Differential, Suspension
ARB $435 to $479
ASFIR
Bud Built $1050 to $2039 Example
Demello Offroad (Suspension Skids)
Icon (LCA and rear lower shock) $131 to $183
RCI Example Thread
Shrockworks $1161 to $1321
Total Chaos (Suspension Skids)
Dual Battery Tray
Things to consider:
-Smog Pump (2013+) is in the way :yell:
-Relocation or adjustment of power steering pump and/or AC lines
Bud Built
Kodiak $835 Example Thread
Pelfreybilt $125 (Upgrades stock battery cage to group 31M)
Sidewinder
Dual battery kit for dual batteries on drivers side using Odyssey PC1200 batteries. May me helpful to those that have the smog pump or people that want to use that area on the passenger side for something other than a battery.
KODIAK INDUSTRIES INC.
I like this option, if I am looking and reading this right if I go with the batteries they have I can fit 2 where my one is for when i add a winch someday.
Nice!
Nice!
Yes. I run that setup. It works great. A little tight fit but it fits where the stock battery was.
I like this thread. It would be nice to add similar info about.
- lifts kits
- UCAs
- Typical wheel sizes (width, offset) that work with 33" tires
- Typical Tires sizes
- Typical Tires AT/MT
- Locker options
- Onboard air systems
- Lighting
I know you said there is too many options, but if individuals added suggestions and one person consolidated it would be a great one stop starting point.
Also, you are missing ARB for skid plates.
http://www.arbusa.com/Uploads/PDF/newProductAdvice/ARB_ToytoaPradoFJ_UVP.pdf
Demello has a few different products for the 5th gen
Added Demello, thanks!
It's almost as if engineers can't help themselves from making lists. :spy:
Guilty! Hopefully it helps people like it helps me.
- lifts kits
- UCAs
- Locker options
- Lighting
Added ARB skids. The things you listed are very useful but difficult for me to consolidate especially since I haven't completed my research on them yet and there are already hundreds of threads about them. I'll see if I can update this in the future when I get a chance to look into it (or if someone volunteers to do the research!) Thanks for your support!
Philthyphilthy
