7.5" Clamshell W/ ARB Locker Installed 4.30 Gears $1000 NC
I was one of them, I want it bad but i'm just not sure how to swing the purchase with the holidays coming up. Was this "setup by ECGS"? meaning does it carry the awesome warranty that you guys seem to be known for?
No unfortunately we won't warranty it. But, I have a lot of confidence in it, and I doubt it would ever fail....the ARB makes it so much stronger than the stock case.
The thing about clamshells is there is virtually zero deflection from the ring and pinion, which is why they rarely fail. Typically any failure will be from the spider gears...but the ARB uses much stronger internals. As as result your failure point would likely be a CV axle even with your upgraded units.
The ARB will still have its warranty (2 years)
