95 4 runner engine problems
You might check to see if the truck is throwing any codes. It seems like it is searching for idle as if the o2 sensor was bad, or the regulator is having issues. I would start there first then work my way through the basics.
regards
regards
Well for some reason my check engine light doesnt work... at all... I tried changing the bulb and no luck.
Nice video! My honda snowblower does a similar surging when idle once warm (the fix there is to clean the carb, particularly one of the real fine holes on the fixed jet).
In my 92 FSM, page EM-81 for troubleshooting the 3.0 3VZ-E engine, they call it serging instead of surging. Their 5 things to check, in order of checking them, are:
1. Fuel Pressure Regulator
2. Spark Plug
3. Distributor
4. Injectors
5. Engine and ECT ECU
If you don't have one already, get or download a FSM. It gives pages for each of these things on how to check them.
seltzernator
