___CLOSED: 2015+ Accessory Meter Conversion Harness Group Buy____
Status
Not open for further replies.
Got mine in the other day, thank you :cheers:
Now to find a display :ranger:
Awesome! You are welcome! The search can be a pain in the rear, but it is worth it once it is installed in the dash.
Just an FYI, another member who purchased the harness from me went an ordered a new display through Toyota, and was told they are currently on back order. I have verified this myself, and was told that stock is about 3 weeks out. It would seem Toyota did not stock many of these here in the U.S. as my guess is they did not expect people to be adding these. Regardless, the main parts depot in California where all U.S. dealers source parts from is out, but stock is inbound from Japan. So, if you end up going through your local dealer's parts department, there will be a small wait.
are you taking any more orders?
[MENTION=211118]TCLLC[/MENTION] [MENTION=129627]BADCLOWN[/MENTION] Yes, I am still taking orders for the harness as they roll in. I will add you both to the list, and will PM you both later today. I am unsure If I will roll things into a new batch, or just fill orders as they come in. I produced a few extra with the last batch so I have some ready to go, but will need to make more for the next batch. I am currently in process of working on a few projects like this, so I will be slow to update/post here, but will check in frequently. As an FYI see my last post about there being a back order for the displays through Toyota right now. I have updated this on the main post as well. Displays are ~3 weeks or so out.
-Tanner
-Tanner
thank you!!!
-Tanner
Still cant get the SR5 to work?
[MENTION=243613]Justhere4aday[/MENTION] It's a problem I am currently working on, so don't give up hope, and be patient with me lol. It took me 9 months of testing to get the last mod working but this one is turning out to be tougher to crack than the TFT for the TRD/TRAIL trims. Here's why:
The last real breakthrough I had was figuring out that Toyota did not change important portions of the software programmed into the main controller on the instrument clusters between 2014+ SR5/Limited and TRD/Trail clusters. The only difference I know of is that the 2014 Trail cluster does not display the multiterrain select mode in the internal screen like the 2015+ models do. This is helpful, but not enough.
Beyond significant hardware differences between the SR5/Limited and TRD clusters the problem really is with the LIN bus protocol. The TFT requires the Lin Bus to be synced via an external clock. The cluster itself needs this as well, and unfortunately the component required to do this is the crawl control switch on the overhead console. Even if I could add an external clock mechanism to override this, I still need to address the Lin bus software protocol, which requires a master node to run everything. The master node acts as the go between for the cluster and display. It "requests" information and then "sends" information. The best way to put it is, if there is no post office, there is no way to get a letter from location A to B.
Without going into too much detail I have a few theories about how to make something like this work, and in general I believe there is a solution, but it is not going to be as plug and play as this is for the TRD/Trail folks.
-Tanner
Sign me up,
newemi 2016 T4R TEP
Was able to pick up a 2014 trail clock for $60 shipped on LKQonline.com ... now that I have mine, I can share :clap2:
For those who are looking, enter 2014 4runner, than proceed to "radio-nav-gps", followed by "info-gps-tv-screen" You'll have to look through all the listings to see if there is a 2014 trail for each listing. Then cross your fingers that they send you the right one (: Or you can try your luck with car-part.com
Sign me up,
newemi 2016 T4R TEP
Thanks for sharing. Did you get yours from Topeka KS?
https://lkqonline.com/2014-Toyota-4...r-clock-and-temperature-Limited/+i~185084981/
Yup, That's the part I ordered. That's why it shows on their website, but you can't order it (: Just crossing my fingers that they get it right, LKQ like most dismantlers are hit and miss. Topeka is one of the biggest locations, sooo, hopefully they can nail it for me!
I called them up specifically asking about that part, and they said it was sold. Good on you!
Invoice received and paid! Thanks again.
If anyone has a lead on a unit to go with this harness I would greatly appreciate it.
Sign me up,
newemi 2016 T4R TEP
Did you already receive it or just placed the order?
Please let us know how it turned out.
Hard to find but I got one! If you are searching LKQ look under gps, display, navigation. NOT under clocks.
Love the orange matching the knob indicators.
That happened to me. Sometimes the parts pickers don’t pay attention to the VIN and they grab whatever “clock” is on the shelf. I called LKQ. I explained that I need the exact part from the exact VIN and she understood. She searched for “clock” and said she didn’t have anymore in stock to swap me. Well later I found another one online under the GPS category. This time I took screenshots of the VIN I ordered the part from. The right one came second time. I shipped the wrong part back and should be refunded for that soon.
Great job with the harness Old Red. It was easy!
Status
seltzernator
