abs bad problem please help
nedelcumihay
i have 3 faut codes
c1223 malfunction in abs control system
c1246 malfunction in master cylinder system
c1256 accumulator low pressure switch malfunction
changed the abs pump but the same problem
after i delete the errors after 10 km after i push brake several times all traction dash indicators turn ON :(
what part did you replace ? the brake booster assembly ( come with accumulator ) or the booster pump only ? take pic and send it to me if you can . How did you bleed air in the system ?
-replaced ABS pump (complete as picture)
-replaced brake switch (new switch OEM)
-no air on brake system
no the error lights on dash now, errors appear after more than 300KM.
When traction dash indicators turn ON,the ABS function working fine (tested on ice)
rl]
Toyota is Land Cruiser
Crookedcat
