ABS, Slip indicator and Multi-Terrain Light
Tuc4R
I have a brand new TRD OFP that I’ve been changing the lighting on. I recently replaces the high beams with LED’s and DLR module, rear turn to LED, backup to LED. Now this afternoon, I’m getting the ABS, Slip Indicator Light and the Multi-Terrain Select Indicator Light which is blinking. From what I have read, this could be do to RF interference from the LED module/ballast. Or possibly a wheel sensor. I did put back the OEM bulbs, but I am still getting the lights. Do I have to go to the dealer to lights reset?
Man it sucks when you introduce your own problems.:rolleyes:
Did you install HID or LED? Never heard of issues with LED but many issued with HID lights. If you go to the dealer and it's the HID system, they will blame you as they should, charge you for diagnostics, and send you packing. Better off figuring it out on your own. Put the lights back to stock, see if it goes way. If not, leave the stock lights and take it to the dealer for them to fix. If they can trace it back to you and not cover it, by all means, they will.
I did put in HID’s 2 weeks ago, but this just happened. Looks like it could be the HID’s then.
Disconnect the battery, take out the HID's, see what happens. Did you lift it or anything, wheel it, deep water crossing? Wheel sensor wiring is very fragile, people damage them all the time.
That was going to be my next step. No wheeling yet, and haven’t lifted it yet either. I have washed it a few times, but that’s about it.
I have also read about bad wheel sensors.
Thanks for the reply.
Well after getting really frustrated, I decided to go get pizza and some beer and think things over. Well 2 minutes into my drive all the warning lights go out. The only thing I did was put back the OEM high beam bulbs. Here is a link to the bulbs I got, there is a DRL module you need to get so that the LED’s don’t flicker. So that must be causing the issue, I just installed the LED’s without the module, so I will see if it’s happens again.
9005 Xtreme LED CMB Fog Light Bulbs | 9005 LED DRL Light Bulbs
lindwlson982
