After market wheels 17x9 et25 no spacers
Ghostrunnerr
Hi fellas...anyone running this set up without spacers? Wondering if this will clear our 4th gen without any rubbing issue running 265/70/17 tires
Let's see, the stock wheels are 17x7.5 with 30mm offset, compared to 17x9 with 25mm offset.
So, 30mm=1.18"~1.2", and 25mm=.98"~1". Therefore the backspacing of the stock wheel is 4.95" and the wheels you're looking at are about 5.5". Running the same width tires as stock means you'll probably have some rubbing, maybe on the UCA's.
Personally, I would look for wheels with 0 offset or run those wheels you're looking at with 1.25" Spidertrax.
For reference check out these links:
https://www.rsracing.com/tech-wheel.html#backspace
http://www.toyota-4runner.org/engin...es-audio-accessories/60465-max-offset-bs.html
I really would like to eliminate the spacers..anyone running spidertrax spacers on their aftermarket wheels? Will it be safe to use?
I have the spidertraxx on 17x8 wheels. no problem, just a bit of rubbing on full turn, even with a daystar spacer lift
