Aftermarket driveshaft recommendations?
nov74fj40
Member
I have an 01 4runner SR5 2WD - can't get rid of dreaded 60mph subtle vibration even after new OEM Ujoint replacement. Looking for options - looks like I'll need a new drive shaft. OEM expensive ... any aftermarket recommendations?
I'd put up on jack stands or lift, front wheels chocked. Tires off, with a helper, run it up to speed. Check it out. If not found, put tires on and do over, be careful. I just dropped off my drive shaft to be redone and balanced. We'll ser
The 2WD driveshaft is very simple. Front slip yoke, two single u-joints. Any decent driveline shop should be able to make one for you. No double-cardan joints or slip joints to worry about.
If new u-joints and balancing didn't fix it, the shaft itself has problems. The rubber vibration dampener wears out and allows the shaft to bend, basically.
I paid $400 for a 100% brand new one from a local driveline shop here in Los Angeles before I went 4WD.
Its a quick 4 bolts/nuts to swap it out.
-Charlie
who did you by from for $400?
It was a local shop, I don't even remember the name now. This is a well known issue (at least, to driveline shops!) and most places should be able to put one together - even if they hack up your stock one to re-tube it.
-Charlie
-Charlie
Call here and ask for Kyle. He has always helped me, and has answered my questions even when it was clear that the DS was not my problem. He may be able to diagnose for you over the phone, and give you an idea of what the problem is.
http://azdriveshaft.com/
If you end up needing a shaft, they can ship and they do outstanding work!
Good luck, hope you get it sorted out quickly.
I'm sure [MENTION=7105]Scramble[/MENTION] would recommend a tom woods driveshaft
Sent from my HTC6535LVW using Tapatalk
delislerebecca
