Alignment complete kit.
calcrc
Hi guys, here is a list I made to completely change the alignment caster and cams. Tell me if I am missing something :)
My question is, if I decide to do the change will it be better to wait and change my UCA's or if I keep them stock... I have full OME suspension and I run stock UCA's for the past year and a half with only issue is the alignment that pulls a bit to the left. Tires are worn normally maybe a little bit off but no issue.
I ask because they have trouble with the cams and caster saying they are really jammed up :/
Other than that all is good.
let me know what you guys think. Here is the link
https://www.toyotapartsdeal.com/onl...model=&Filter=(1=1GRFE;6=5FC;0=GRN280L-GKAGKA))
Grrrrr works when I click on it, here is a file I saved.
Part Description Price
Qty. Subtotal
Part No.: 90178-16007
NUT, FLANGE
Remove
$1.59
$3.18
Part No.: 48198-60020
CAM, CAMBER ADJUST
[Toyota | 4Runner | 2011 | 1GRFE | 5FC | GRN280L-GKAGKA]
Remove
$14.63
$29.26
Part No.: 48655-60050
BUSH, LWR ARM, NO.2
Remove
$60.54
$121.08
Part No.: 48190-60040
CAM ASSY, CAMBER ADJ
Remove
$14.69
$29.38
Part No.: 48452-60020
PLATE, TOE ADJUST, N
Remove
$17.90
$35.80
Part No.: 48654-60050
BUSH, LWR ARM
Remove
$47.04
$94.08
Part No.: 48409-60040
CAM SUB-ASSY, TOE AD
Remove
$15.89
$31.78
Part No.: 90119-16005
BOLT, W/WASHER
leolediola
