Rc4r New member May 28, 2011 #1 Violent right side pull after lift and tires, could this be tire rods and rag joints?
YotaZach85 New member May 28, 2011 #2 Did you have it aligned after the lift? Sounds like your out on tow and caster pretty bad.
Rc4r New member May 28, 2011 #3 They guys at the shop messed with the alignment for three hours and he couldn't get it to stop. Im taking.to alignment specialist Tuesday
YotaZach85 New member May 28, 2011 #5 Your rack bushings may be worn, causing some issues, but the specialist will be able to tell you for sure.
Rc4r New member May 28, 2011 #6 Volley said: Did he give you a printout of your specs? Click to expand... What do you mean?
YotaZach85 New member May 28, 2011 #7 Rc4r said: What do you mean? Click to expand... If they used an alignment machine they should have given you the sheet that shows what spec is and what your truck is actuallt set to in comparrison.
Rc4r New member May 28, 2011 #8 Ohh okay, no they didn't do that. It was done at an offroad shop so idk how they went about it but I'm taking it to firestone to see their alignment specialist. Hopefully he can figure it out
TheDurk Elite Member May 28, 2011 #9 YotaZach85 said: If they used an alignment machine they should have given you the sheet that shows what spec is and what your truck is actuallt set to in comparrison. Click to expand... In fact, get both before and after print-outs. You will see how bad it was when you went in.
