alignment on 85
canopypilot
anyone have instructions for setting alignment up on the 85, i used to have it for a 70 landcrusier which is close to the same but i cant find it. I have a pull to the left. my guess caused by the tires and lift. its not super hard but if you let go of the wheel it turns left kind of fast ?
The only adjustment is toe-in. You can use the string method and set it for about 1/4".
If you have lift springs your caster is likely off, which can lead to wandering or darting, depending on the road surface.
Most lift kits come with degree shims to correct the problem.
The shims are installed between the spring and the spring perch on the axle.
ghengiskhan
