alignment program?
Morphyne
So I am at the shop getting new tires and alignment and the alignment os $85 but the 3 year program is $150. Anyone ever get the alignment program? Is it worth it?
Sounds like GoodYear and I passed but they have a 3 month standard for $85 which I used 3 times simply because they did such a crappy job.
Had the Firestone lifetime alignment on my Tacoma and will be doing the same on my runner. if you rotate regularly or off road it, going 2x will pay for itself. Its a no brainer unless you're selling the vehicle soon.
On 4th gen, after an alignment front end work, etc... Really should be plugged into a scanner (dealer, buddy with a snap on, etc) and have some things reset.
Story time...
Couple of years ago, I did 3" front and 2" back on all my stock xreas, 285/65/18s on some offset xd wheels. Went and got an alignment, still pulled and drove weird. When decelerating, it would sometimes just jerk around. Went and got another alignment... Same thing. Just learned to deal with it for 75k miles.
I have a snap on solus pro... Never had the need to plug it into the 4runner... Never had a check engine light or anything. Just did front brake calipers, due to the typical pistons freezing up on the 4 piston rotors, and I was too lazy to bleed the brakes manually so I used the scanner to bleed them. While going through settings I saw that there are multiple sensors affecting ride quality after an alignment.
Went through a "zero point calibration" procedure.. Reset "steering angle, decel sensor, yaw rate" along with the "wheel alignment" procedure which honestly I think did the same thing as the zero point calibration.
The next day, my 145k 06 limited v8 that I've proudly owned since day one, drove better than it did at 70k... Hit the highway, no pull.
Little food for thought
PS... That was my first post... That thread actually made me join just so I could reply and spread the news... Lol
Story time...
Really? That's a thing? I had no idea...
Where can I find instructions on how to do this?
