Alpine power pack install questions
MikeyMTBs
Have installed the Subaru tweeters and they made a world of difference but, still just need some more power to the stock speakers. I’m interested in installing the Alpine KTP445u power pack. Vehicle is a 2019 TRD ORP. My questions are the following:
1. Is there room to install this small amplifier behind the stock radio somewhere in the dash?
2. The unit needs 12v power via a 15amp fuse. I’d prefer to use a fuse tap to pull power from the inside fuse box. If you installed the same, which fuse location did you tap into for your 15a, 12v power?
3. Are you satisfied with the power this small unit provides?
4. Were you able to find a male & female Toyota harness to splice into making inline installation easier and not having to cut the factory connectors?
Long term I will install an OEM Audio+ system and a new head unit but am holding out to see if Toyota provides an update to the stock unit that adds CarPlay.
Thanks-
Fish4runna
