_ExpeditionMan
I know I know this has been discussed dozens of times... I apologize and will try to make this one a bit different!
For reference: 1994 4Runner 3.0 5spd
This question is directed at anyone who has adjusted their idle (via the screw) and had the vehicle auto-adjust itself back to a low RPM.
Essentially, the 4Runner started idling at ~500 RPM a few weeks back. Did a cursory search on the internet, found the adjustment screw, adjusted, and thought I was good. I have attempted this a few times thinking maybe I was crazy, but each time I adjust to the FSM suggested 800-850 RPM the engine will drop back down to 500 RPM after a few days.
~1.5 weeks ago I had the Timing belt, water pump, and associated items replaced so I assume the engine has been timed properly. Additionally, if I give it some gas to hold the idle at ~800 RPM the engine runs super smooth and it only gives me slight vibrations at 500 RPM.
I am aware it could be a variety of things from vacuum leaks, to the TPS, or MAF... exc. What I am asking is:
1) Have any of you encountered this "self adjusting" low idle after idle screw adjustment?
2) Where would you start with the diagnosis of this?
I almost didn't want to ask this question based on how often this seems to come up for these. Thanks for the help and patience everyone.
