Another wheel fitment 231mm brake upgrade question
SoCalVibe
I have been through a lot of the threads on this and I am 90 percent sure I have this right, but just need confirmation on this statement...
1997 T4R 4wd the 231mm front brake upgrade will NOT work on 16" wheels.
Depends on what wheel. Put up a pic and we will let you know if they clear.
photo.php
[MENTION=117072]SoCalVibe[/MENTION]
Save the picture to your device/computer then attach it using the attachments feature when making posts. Linking from fb doesn't work well here.
The split 3's wont work with the 231's without grinding.. Unfortunately, I think they're the only 16" factory wheel that doesn't work with the big ones.
[mention=117072]socalvibe[/mention]
save the picture to your device/computer then attach it using the attachments feature when making posts. Linking from fb doesn't work well here.
edit: deleted attachment as size was annoying
I know that I have 1/4" wheel spacers in the front. Not sure if that would help. What would I have to grind?
You need to grind on the wheel. I would also get them balanced if you go that route. I run a 1.25" spacer that helped me clear the brakes and clear the UCA when running larger tires.
The calipers fit with the 16s and the spacers without having to grind the wheels. I did have to trim the backing plate a little. Now my guy says the caliper bolts wont work. (Too long?)
Is this right?
premiumusedautoparts
