Any T4R.ORG Badges?
So,
No money will pass thru me, please go to updated post #2 for the details!
Thx
Saker-
Thanks for getting (and keeping) the ball rolling on this---the sample renderings look great! Couple of quick questions if you don't mind:
1. I'd love to be added to the list. I'm particularly interested in the "limited black" version Craig mentioned in his message so would you let us know if he needs a head count for that specific version?
2. Now for the really dumb question. I'd originally assumed that these would be adhesive badges (like many people apply to the back of their vehicle with a sports team or college logo in chrome), but as I read further into the thread I noticed that you were also discussing "grill badges" with mounting posts. I guess I'm not familiar with that concept. Do they replace the Toyota emblem on the front of the vehicle? I'm having a hard time picturing how the "grill" version works.
Grille badge.
Saker-
1. No need at this point to be added to the list as I see it. I guess as far as getting a limited black on, it may be on a first come basis. And who knows, he may make more as it all depends on him.
2. Each one is approximately 3" in diameter, weighs about half a pound and is individually number stamped on the back. These babies are solid! The fronts are coated in epoxy to protect it from the elements. The stud mountable badges come with two threaded studs and the mounting bracket necessary to get this beaut on your grille in minutes! (As mentioned in a previous post)
2 studs are screwed into the back of the badge, inserted into the grill opening and a backing plate is then placed on the studs behind the grill, then the nuts are placed and tightened on the studs.
Grill badge pictured is larger than the ones in this thread.
It does not replace the OEM emblem!!!!
Hope this helps
. : : MOST RECENT UPDATE : : .
Craig responded to the adhesive backed question, so here is his answer!!!
"Hey man, I saw your guys had some questions. We'll run adhesive backed ones of the red and black design too. No need for lists. The red and black will be available as long as your guys and gals are interested. We'll probably do about 20 of the black on chrome ones.
Cheers"
Looks like great customer service on Craig's part!
Hope this helps
Hey, Saker---just curious to know what that badge is that you've currently got on your grill?
This is what I had on it at the time I made a vacation trip to South Florida, it was previously on my FJ.
A buddy of mine in Islamorada FL sent it to me when I still had my FJC.
[MENTION=103267]Saker[/MENTION]
I just wanted to say thank you for organizing this and getting our input! that badge is awesome!! Kudos to the guy who's making it and drew it up!:bravo:
[MENTION=109283]9494runner[/MENTION],
Thank you sir!
Thanks to Craig for the design and making them for us.
Add me to that list as well. The red & black is awesome. :)
No need to be added to the list. The designs have been decided
So subscribe to the thread and when the badges become available, it will be posted.
You will go directly to the link on the 2nd post of the thread and make your purchase.
Hope this helps!!!
. : : As of today, Craig has made available the T4R badges. Go to post #2 for directions on ordering directly from War Rocket Industrial ! : : .
This one is for the 4heads, a badge five generations in the making! This red and black on polished chrome T4R.org Grille Mounted Badge will be remain in unlimited production. Each one is approximately 3" in diameter, weighs about half a pound and is individually number stamped on the back. These babies are solid! The stud mountable badges come with two threaded studs and the mounting bracket necessary to get this beaut on your grille in minutes! The badges mount universally on most grid or mesh front grilles. Just screw the two included threaded studs into the back of the badge. Then position the badge on the grille where you want it, with the studs through the grille. Finally, use the included nuts to anchor the included mounting plate against the inner side of the grille. and voila. No drilling, no need to remove the grille and completely and safely reversible.
This one is for the 4heads, a badge five generations in the making! This red and black on polished chrome T4R.org adhesive backed badge will be remain in unlimited production. Each one is approximately 3" in diameter, weighs about half a pound and is individually number stamped on the back. These babies are solid! Each of these badges comes with auto-grade emblem adhesive pre-applied to the back. Just use the included alcohol wipe on any dry, clean, and flat surface where ever you want the badge, peel it and stick it and you're done.
This one is for the 4heads, a badge five generations in the making! This black on polished chrome T4R.org Grille Mounted Badge will be remain in unlimited production. Each one is approximately 3" in diameter, weighs about half a pound and is individually number stamped on the back. These babies are solid! The stud mountable badges come with two threaded studs and the mounting bracket necessary to get this beaut on your grille in minutes! The badges mount universally on most grid or mesh front grilles. Just screw the two included threaded studs into the back of the badge. Then position the badge on the grille where you want it, with the studs through the grille. Finally, use the included nuts to anchor the included mounting plate against the inner side of the grille. and voila. No drilling, no need to remove the grille and completely and safely reversible.
This one is for the 4heads, a badge five generations in the making! This black on polished chrome T4R.org adhesive backed badge will be remain in unlimited production. Each one is approximately 3" in diameter, weighs about half a pound and is individually number stamped on the back. These babies are solid! Each of these badges comes with auto-grade emblem adhesive pre-applied to the back. Just use the included alcohol wipe on any dry, clean, and flat surface where ever you want the badge, peel it and stick it and you're done.
Hey guys & gals,
I think Craig did a nice job (as always) on these badges....
Please give him kudos if you would on the badges when you post!
Mike Sargent
