ANyone remove Roof Rack from a '19 TRD Pro
mswaz
Looking at removing the roof rack from my 2019 TRD Pro. Don't care for the look. I removed the roof rails from my 2018 Land Cruiser and my previous 2017 4runner Pro, but those used hex bolts and this has Torx bolts. I do have the roof rail delete kit from Toyota for removing those rails and to seal up the holes but not sure if it'll work on this rack.
Anyone remove it yet? I assume its the same holes and location points as the other 4Runners.
I just removed them...t40 torx and yes all 5th gens are the same. It’s a PITA with the red loctite. tip, don’t break the screws loose w/o the other pair still in and use PB blaster (or equivalent).
There is a bracket that holds the pair of 2 nuts (where the screws go in) tac welded to the underside of the roof that can break off. If this happens you cannot unscrew them since the nut on the underside of the roof with the bracket will spin freely. I ended up having to take the rear headliner down a little to access the nuts and bracket.
Hard to explain but I will post some pics shortly that should help.
The bracket is twisted but I hope this helps
There was a guy on the lexus forum that put 5th gen OEM rails on the GX460. I can't imagine that they'd change the design for the new and improved FJ rack. It's weird that they used torx but the bolt pattern should be the same.
Yep, the torx was weird. I ended up finding the brackets at Toyota $3~ each and switched out the hardware with stainless hex head bolts. M8 1.25 and 50mm length and some 5/16 washers .
Sent from my Pixel XL using Tapatalk
Bolts
What is the difference or preference in using either bolt I’m about to mount the 19 pro rack on my 18 ofp which should I use
Mike
It’s definitely not for everyone. I think it looks hideous. It worked beautifully on the FJ. On the Runner...meh...but again, someone will jump all over this. Especially since the dealers are demanding a TRDP VIN to order. Kind of adds more value to those selling. Just saying.
Posted this in a similar thread as well but I'm wondering if this is a design exclusive to the 19' Pro only:
Hey I also just removed my 19' rack but had to be super careful not to lose those brackets in the headliner. I've got the delete kit on now but I'm concerned that when I get my Gobi rack the mounting hardware won't fit that bracket or i"ll lose them in the process. Seems when it arrives I might have to remove the headliner entirely to be able to access all 4 brackets.
Is the 19' Pro the only one with that backing bracket style?
I deleted mine. I hated that thing
I got the delete kit on Amazon
Had to fight with the bolts to get them out, I could not believe how hard they came out but I worked them back and forth just a little each way until they were finally free.
I love the way it looks without them.
seltzernator
