Anytime Backup Camera - Summer 2017 Group Buy
Thanks for the discount on your hard work!
As an aside, does anyone know of a DPDT (not momentary) switch that has a good fit in the dash?
Thanks!
Thank you all for the orders! Everything is queued up and should start shipping on 8/8/17. I will keep the coupon code valid through 8/11 so get your orders in before then if you would like to take advantage of the discount.
Thanks!
Just a question i guess.
I see the back up anytime it you keep the camera wire untouched but cut the signal wire so it tricks it.
In the dual camera, you have a switch to select which one you want to view.
In the dual camera car harness i only see the rca input and output but dont see a break for it.
Is the harness for the "full kit" different looking or will it be 2 seperate harnesses
I assume we need 2 switches, 1 for front/rear, and one for the anytime harness.
I have to same question - but figured I'd just wait til my order came in to figure it out. Might as well find out now hahaha.
As for the switches, you'd either run 2x SPST or 1x DPDT.
2X SPST I GET
1 FOR ACTIVATE ANYTIME
1 FOR FRONT/REAR CAMERA
1 DPDT?
UP WOULD BE FRONT
DOWN WOULD BE BACK
MIDDLE NORMAL?
you couldnt use a up and down only DPDT i think as you wouldnt want the camera screen on all the time.
2X SPST I GET
1 DPDT?
UP WOULD BE FRONT
DOWN WOULD BE BACK
MIDDLE NORMAL?
I'm just going by what was recommended on his website.
But a DPDT should only have 2 positions.... On and off
Pole #1
- Terminal 1a
- Terminal 2a
Pole #2
- Terminal 1b
- Terminal 2b
P1 and P2 linked together.
They are either both at T1 or both at T2
Pole #1
- Terminal 1a
- Terminal 2a
Pole #2
- Terminal 1b
- Terminal 2b
Yes you need either two SPST or one DPDT. With the the DPDT you would have up as front cam and down as back cam and middle normal operation.
DJNutshell
