Arc Light LEDS - 5th Gen Interior LED upgrade white/red
dot_tom
After browsing Instagram one night I came across Arc Light LEDS and their new 5th gen 4Runner LED light kits. They made 40 of them and I was quick to pull the trigger.
https://www.arclightleds.com/
The front lights have dimmer switches and buttons to flip from white to red. Really slick setup.
These come packaged very well and full-color installation instructions. Really easy to install. This is just a post of what I bought and installed.
I also picked up a battery voltage booster. Figured why not. Not sure if I'll use it. Still planning out my electrical upgrade route.
Perfect fit.
Measured twice and drilled a couple of times. Started out with a small drill bit and worked my way up test fitting the part and making sure I was keeping the holes lined up where needed and not bigger than needed.
I was impressed how well this came together. I was a bit worried about the buttons lining up but it was easy.
Only picture I have of the front lights installed in Red.
I picked up their rear hatch lights as well. These are super bright LEDs that have a dimmer switch.
Out with the old.... in with the new.
All set up and ready to drill some holes.
Color is weird from the camera phone. These are super bright.
First impressions, great product! These are a bit pricey but great quality and a cool upgrade. Worth the money IMO.
nice, I was able to snag one of the front lights like yours - no install yet, but very excited
Easy install even with drilling. If you plug them in and they do not light up, make sure to turn the black piece 180 deg. That was one problem I had on the driver side light. I flipped the plug 180 but the actual black piece needed to be turned 180 deg. You'll understand better once you go to install it.
Nice! I picked up the hatch lights and the voltage booster. I figured I use the hatch lights more than my dome lights.
I went with the dome lights also to use the red function. Figured I might use it a time or two. Who knows.
Not sure about the voltage booster. Still trying to figure all that out.
Nice. I got the map and tailgate lights. Missed out on the center one.
Just installed the lights last night. I thought the led replacement bulbs we're bright but these take it to another level. Love the switchable red/white map lights.
Sent from my SM-G935T using Tapatalk
efffffff...wish I knew about these sooner. The option to have red map/hatch lights would be a game changer for trips/camping
got mine installed the same night i got them! awesome upgrade for sure. red is awesome, but wife still blinds me out of nowhere with the white maplight.. just because
Messed up Install
I have all three (dome, map and hatch), on the map light I got the version with the buttons to turn them red, however, I misaligned the holes for drilling and messed this plastic lens piece up. I am having difficulty finding the part number or where to get a replacement. Right now I just have a really big hole to accommodate the replacement light in order for it to work. Does anyone know the part number or where I can find a replacement for that specific lens for the map light (the one you drill into - center piece in the overhead console)? Thanks in advance.
Picked up some hatch lights few days ago. Will drill and install them tonite! I am holding off on the dome/map lights for now, but eventually I will get them as well.
Thanks OP, nice find. Seriously looking at the dome and hatch lights. I do have a question, how far does the toggle switch stick out and would you guess it would take a little abuse. Thinking about having a bunch of stuff loaded in the back and having to force the hatch a little bit to get it to close or the cooler sliding a bit and whacking the switch. Do you think it could handle something like that?
Regardless from the pictures it looks like interior lighting won't be an issue any longer.
Ya, they come in pairs. $79 for white $109 for red/white switchable. For the switchable ones you need to drill a 5/16" hole into the plastic lens. I used a drill press and a step bit and go SLOWLY so that the lenses dont crack!
