Automatic transmission 2nd gen 4runner
knightlogger
Hey guys how decent are the automatic transmission in the 2nd gen 4runners with a 3.0 ?
haha are you joking? They call FJ55 the Pig but I think they mean any toyota 4runner with an A340 trans.
mine does OK with 35's, 5.29's. I get about 12-14 mpg depending on if I am going down hill with a decent tailwind.:yield:
if you can find one with a 5 speed get it
Well I had one with a 5speed and made the mistake of giving her up for my wife to get a new car. But I'm asking about the automatic because my buddy is hooking me up with another runner but it's an automatic
looks pretty clean but it's isn't gonna be the fast horse out of the gate and your mpg will be lower than your old 5 speed.
Only reason I got an auto was I got the 4Runner for $400 from a family member
Lol I know its no soeed demon. My 95 was pretty slow I pretty much called her the slow runner. What gear ratio is most common in the automatic ? Also would it be a pain to swap it out for the Manuel
Some hints, but these wont help the mileage.
There are 3 different ways to control the 4Runner's A/T:
The PWR switch will space the shift points farther apart. It works like a Load/Haul Switch in domestic trucks, Good with a load or a tow. Improves acceleration a tad.
Disengage the O/d. Much better acceleration than using the PWR button. Shifts and runs like an old fashioned Turbo-Hydramatic. Miserable MPG, though. Improve getaway further by using the PWR switch.
Both of the above work well in surface street urbanity, because you won't be going into o/d much anyway, as well as needing quick acceleration for any number of reasons.
Manual shifting: Not recommended for normal driving, but good for overtaking on two-lanes. Just drop a gear out of Drive. Better if you disengage the overdrive at the same time. After you've passed go back to D and engage the o/d. Don't power brake and slam shift like a drag racer- unless you enjoy replacing trannys.
With all these, watch the revs.
The 4-speed auto is usually the equivalent of the 5-speed manual. The torque converter takes the place of gears 1-2 in the manual, while the o/d is 4 in the auto and 5 in the manual. The big difference is the clutch makes for virtually direct drive to the tranny, while the slush in the t/c cuts the auto's efficiency- lower MPG and slower acceleration.
If these trannys have a lockup t/c all the better.
If you study autos and how they work, you can get a bit more out of them. I'd bet some would be surprised. And your left leg won't get tired in traffic jams either, just your right one...
AndiGarage
