Axel comparability?
Fochps
Will a 99 rear end bolt up to my 97? My diff is whining and I found a great deal on a 99. The donor is 2WD and mine is 4WD. Thx guys!
i dont think that will work.
arent the 2wd's 5 lug?
i know the older ones were, not sure if they changed it.
but, even so, the gearing is likely different. 2wd are usually geared higher.
My 99 was a 6 lug with 16s.
As long as the gear ratios and lug pattern are the same, it should work.
You can determine the gear ratio by checking the axle code on the VIN plate.
Down at the bottom, a letter and three numbers (G254 for example).
2001ATL
