Aziz4Runner Build Thread
Fog Lights
Got some 8" Fog Lights off of a friend and put them on the brush guard.. Next up... roof rack..
Ok. Mine is lifted, details in signature. Is the body lift necessary to fit 33"? Also, are you using wheel spacers? Been thinking about moving up in tire size, so I figure I would ask you now since you are running 33". Thanks.
Nope.. no wheel spacers. I got rims that were 18x10 and had a -25mm (about 1inch) offset so I didnt need to get the spacers.
Roof Rack
Built a custom roof rack with a friend who made on for his Hummer.. Took it to the garage at work.. Close fit!! Less than a quarter of an inch to work with.. thats how its done!!
Nope... No spacers but I got the rims with a -25mm offset..
So right now , i'm piecing together my LC8/trd tundra lift and in order for me to have 285's everyone says i'll need spacers which i really dont want to get.. so if i get wheels that have an offset i dont have to correct?
Make sure your offset is about an inch (-25mm). Anything less than that will probably rub against the upper control arm
Roof Rack Powder Coated
Got the roof rack powder coated... now just need the lights!!
Lights on the Roof Rack
Got some night shots of the lights on the roof rack.. more pictures to come
LED Lights with roof rack
Put on 2 LED light bars on the front, 1 light bar on the back and 2 side marker lights on each side..
that is the look i want!
just some fat n nasty tires holding it up, rack with lights up top.
let me know more about your lights, and more pictures of how the rack bolts up, is anything holding the front part up?
I got the lights from superbrightleds.com and got 2 14.5 inchers for the front and 1 for the back. Got some regular daytime running LED lights for the side. They light up enough for you to see what youre stepping into if you get out. Bolting down the roof rack, we just used the bolts from the old roof rack and replaced the old bolts on there. Nothing is holding up the front for now but looking to get something on there in the near future
tuṣṭāva
