Battery Terminal Distribution Block Suggestions
97BlackAckCL
Elite Member
Thanks, I was looking at those also. All my relay harnesses do have fuses inline however
You will want to go the fuse block/sPod route (trust me). Otherwise you're going to end up with an engine bay full of spaghetti. Do it right the first time and you want have to clean up a mess later. Ask me how I know :(
Trying to avoid that, that's why I'm looking for suggestions. So with the fuse block setup, would I have to remove the inline fuses from the relay harnesses?
So a good rule of thumb is to always have your fuse as close as you can to the battery. A power wire from you battery goes to the fuse block, which is mounted relatively close to the battery. Then wires for you accessories are powered and fused from the fuse block. This is incase of a short circuit. Here is a link to a great explanation of this. Skip to 49:40 of the video.
https://www.youtube.com/watch?v=zbWSSKyOYgU
Murphy's Law will be applicable, the ring terminals included on your harnesses will be too big or small for the fuse block you purchase. You might get lucky with a couple, but fully expect to put some new ring terminals on. That gives you a chance to remove the inline fuse holders which aren't required after a fuse block.
I'm looking at the same thing coming up for my truck, and am not looking to re-routing and maybe having to extend some wires!
even if you buy a fuse block you'll still have to find somewhere for your relays so it will still be messy, i'd either go ahead and get a fuse/relay block or just do something simple like a common bus bar and use the wiring harnesses you have
I already have a relay mount so that part should be tidy, just trying to figure out the cleanest way to power everything without cluttering up the battery terminal
I'd recommend this if you're able to get it..
https://www.ebay.com/itm/323210903128?ViewItem=&item=323210903128
Here's my setup:
