BEST Offroad/Trail Communication Handhelds
Having a way to communicate with each other on the trail is vital! Situations where your spotting its a great tool to use and will allow you to help out your other offroaders without screaming or just using hand signals. Having some communication on the trail in case of an emergency is critical as well! Situations arise where emergency services may be required and phone service is not always available. By getting yourself one of these radios, you will have access to both! These radios come with everything you need and more! pre programmed with over 150 channels and works flawlessly with rugged radios and pci products as well. In stock and ready to ship!
CLICK HERE TO PURCHASE YOUR RADIO TODAY! FREE SHIPPING AND READY TO GO OUT OF THE BOX!
T4R MEMBERS ALWAYS SAVE MORE! USE PROMO CODE T4R FOR A DISCOUNT AT CHECKOUT
FEATURES INCLUDE
BaoFeng UV-5RTP (TriPower)
1800mAh, 7.4v, Li-ion Battery
Antenna
Extended Range Antenna
Preprogrammed with over 150 channels
Power Adapter
Earpiece
Belt Clip
Hand Strap
Battery Charger
User Manual
Features:
25KHz/12.5KHz Switchable (Wide/Narrow Band)
FM Radio (65.0MHz-108.0MHz)
LED Flashlight
High/Mid/Low RF Power Switchable
VOX
50 CTCSS/ 104 DCS Tones
Tone searching/scanning
Dual standby
PC programmable
Transmitter time-out timer(TOT)
Busy channel lock-out(BCLO)
SPECIFICATIONS
Frequency range:
[TX] 136 – 174MHz, 400 – 520MHz
[RX] 136 – 174MHz, 400 – 520MHz
68-108MHz (FM Broadcast)
Antenna: High Gain Dual Band Antenna 7” Antenna
Mode of operation: Simple or semi-duplex
Transmitter Output power: 8W/5W / 1W (Max 8W)
Modulation Mode: 16k F3E / 11k F3E
Maximum deviation: 5kHz(Wide) / <2.5kHz(Narrow)
CTCSS/DCS deviation: 0.5+/-0.1kHz(Wide) / 0.3+/-0.1kHz(Narrow)
Intermediate sensitivity: 8-12mv
Interference distortion: <10
The Most Powerful One Yet: BaoFeng UV-5RTP (TriPower). The UV-5RTP is the most powerful BaoFeng capable of transmitting at 8 watts! The UV-5RTP is the third and final generation of the UV-5R. Some new features found in the UV-5RTP are the three select-able power levels (Low – 1w, Med – 4/5w, High-7/8w); the UV-5RTP has a better high-gain antenna (7”) that was not available in earlier models; the UV-5RTP also brings back the customizable tri-color display that was not found in second generation UV-5Rs. The UV-5RTP also comes with a Full IN-DEPTH 76 Page User Manual that will help you get acquainted with all the New Features!
Much like its little brothers (the BF-F8+ and the UV-5R) the UV-5RTP maintains full cross accessory compatibility with all previous UV-5R accessories.
VERSATILE RADIO FOR AMATEUR USE
The BaoFeng UV-5RTP (High Power) is legal for use on amateur frequencies. The UV-5R is able to Transmit on Narrowband (12.5kHz) and Wideband (25kHz).
Dual Watch Receiver
The BaoFeng UV-5RTP (High Power) has one built-in receiver but can “watch” two channels (semi duplex). Monitor two different frequencies (even on different bands (VHF/UHF)) and the radio will monitor both frequencies giving priority to the first station to receive an incoming call.
FM Broadcast Station
You can listen to the FM Broadcast radio, while still monitoring your radio frequencies in the background. Any incoming call will be given priority insuring you never miss an important call while listening to the radio.
Group Tones Supported
The BaoFeng UV-5RTP (TriPower) supports the most common Analog Tones. It supports CTCSS, DCS, and DTMF calling methods. Set-up your calling methods to call by group tones. Tone calling (private line) is required by most repeater applications and the UV-5R supports the latest standards. The BaoFeng UV-5RTP can even send DTMF tones. This allows for sending ANI (Caller ID) or remote commands that require DTMF tones
seltzernator
