Best quality aftermarket 4th gen headlight units?
joneblaze
Hi guys
The Depo aftermarket projector headlamps that came with my 07 V8 Sport a couple of years ago have died - driver side assembly had a turn signal bulb burn out/break off into assembly + melt the turn signal socket within housing - the passenger side seal has broken down and is super condensed and fogged constantly. Neither of my turn signals currently work (problem).
I rather just replace the entire set for a clean new set.
Will be searching for a non cloudy set of used OEMs but failing that, can anyone recommend the best quality aftermarket options currently on the market?
I’m not after any blacked out housing or halo nonsense - just clean OEM looking projector assemblies that will last a decent amount of time. I have a XenonDepot Philips 4300k HID setup currently installed.
Many thanks
Jon
for aftermarket, good brands are usually tyc and depo, i still pass on those, i spend money on new oem set, its close to 450 out the door. never have to worry about leaking and sun damage again.
Appreciate the feedback. Going to pick up an OEM set and call it a day probably :)
I would choose a good used set over a new aftermarket set every time. Every aftermarket headlight I bought it eventually developed condensation inside the housing. But that can be fixed by resealing it with Butyl tape or even silicone.
Yup agreed. Just ordered from my local dealer - they price matched sufficiently against online pricing and came in under the total shipped cost.
Maybe after like 15 years of abuse, but if you coat them when you first get them and take care of them i'm sure they'd last a lot longer than any aftermarkets
no doubt they would/should last a lot longer than aftermarkets.
i recently bought an 08 4runner that was a soccer mom vehicle in great shape & its lights were very foggy & yellowed. cleaned up a lot with mothers wheel polish though.
after searching for 6+ months for the right 4runner to buy & seeing literally over 100, i saw a lot of 4th gens that had faded & foggy headlights at 8-10 years under "normal" care conditions (not coating but not abusing). but thats longer than some will own their 4runners so i guess that can be considered never having to worry about sun damage. :dancin:
Got a set of TYC-stamped black housing ones from ebay (maybe theyre fake, maybe theyre real).
One is perfect, one leaks. both have a little peeled clear around the outside corner.
I'm looking to replace them and decided I'd try these next: https://www.amazon.com/dp/B07Y5QDM3S
They should arrive tomorrow, and I'm just interested in seeing how they look
Hello, I'm looking to replace my 2006 head light units, are you happy with yours?? You've had them a few months now, from your post date. Appreciate feed back. Thanks.
Can you post some pics. I've been thinking about buying those.
TYC from rockauto or Amazon here:
no leaks so far and they run through 3' deep mud holes every other weekend and downpours and rain, no leaks yet in 6 mos. the fitment lines are perfect too
So I purchased these lights of ebay oemassive. So far I'm happy with them only problem so far I cant get the led bar to dim at night. Its extremely bright.
I have a 2009 and my headlights are stock, and super yellow. They also have a lot of condensation inside. I never see water in there, just the residue stains. I only have 100k on it and bought the aftermarket set already. Why has done the aftermarket and had good experience? I hate doing things twice when I can avoid it.
Best for HID projector retrofit
I have a 2003 T4R (reflector housings) and I'm planning to do a HID projector retrofit (Mini H1 or D2S). I'm looking to purchase aftermarket headlight housings so I can continue to use my T4R as a daily driver. My plan is to retrofit the aftermarket housings because the lenses on my current housings are heavily scratched (crashed into barbed wire fence). If I'm retrofitting, does it matter which brand aftermarket headlight assembly I get? I know OEM quality is better, but is it really worth paying $400-$500 for new OEM if I'm planning to do a retrofit? Thank you in advance.
BillM777
