Best way to fix patch of paint on the hood?
Thanks folks, I did not know there was a clear coat over the paint coat.
As pauldub suggested, one possible solution is to spray some clear coat over the bad patch.
As T4R2014 correctly noticed, there was a spot of paint I had removed though scrubbing (I don't even think I used sandpaper!)
IBallEngineer was spot on, but entailed a more complete solution than I am looking for.
For these reasons:
-My 4Runner spent over a decade in New England and is rusting from the inside out(already rusted through the hood at one point).
-My 4Runner is now a city car and already shows over fifty points points of contact with other vehicles.
I am more interested in testing a "20 minutes and 20 bucks" solution to see how far it will take me.
Here is the "before" picture:
Here is the "after" picture showing the four test quadrants:
This was the test kit:
The "Wipe-New" with zero sanding produces a pretty respectable result, and solves the white spots that were my primary concern.
As an added bonus, I was also able to use the "Wipe-New" on all the plastic trim, which is the actual intended purpose of the product.
This is not intended as a permanent solution, but as a fourteen dollar stopgap solution it serves my purpose!
You bought all that for $14? Just that Aerosol can is $11 on Amazon.
Sub$14 referred to the "winner" which was the Wipe New Trim Kit at $13.78+tax with free pickup at Walmart. This is the kind of thing for which Amazon is a bad option, much better is to pick up at Walmart (might need to special order, no minimum for pickup, if entire order is $35+ it ships free to your address.) Spray lacquer was $5, sandpaper was $3 as I recall.
