Bigger transmission cooler ?
Jc12
Hey guys, I have the B&M cooler installed but continue to overheat my transmission once the temps climb in the summer and I load the truck for a camping trip.
It only happens when doing extended hill climbs but I think I need a second or a larger cooler.
Any recommendations?
The Dawg from Hayden coolers? Or maybe just a bigger size from Hayden or B&M, but then you’re going to run into air flow issues for other components.
Did you bypass the stock radiator? If your engine temps are fine maybe think about replacing the stock radiator and re connecting the trans fluid. would be extra cooling.
^^^^better idea look into a champion all aluminum radiator then maybe run your cooler in series
What kind of temps are you seeing and how is the cooler mounted? Do you by chance have a Magnefine filter that maybe needs to be cleaned or replaced?
I prefer to mount my cooler to feed into the bottom and exit out the top. Reason being is that you get more cooling efficiency, heat exchangers work better when they flow this direction because the air bubbles get forced out the top. When the cooler is fed from the top the fluid "drops" through the cooler and that's not ideal.
However you have it mounted though, B&M is a good cooler and i'm curious as to why you're running hot.
What's your definition of overheat? Does the dash light come on or are you just seeing temps over 200 some of the time?
Did you mount the trans cooler right up against the AC condenser, or is there space behind it? You want the stock fan to draw air through it efficiently.
I am also in the camp of people who say to keep the stock radiator cooler hooked up when adding a external trans cooler. With a (newish) radiator and regular fluid changes (coolant and trans fluid) you won't have any problems with a pink milkshake.
-Charlie
Which B&M do you have? What's it's size?
I reckon the OP is MIA for now. It's my guess what he's experiencing is the high temps our auto trans can hit when climbing steep sustained grades. Even if you turn Overdrive off and you have an additional external trans cooler, the transmission temps can go through the roof on slow speed steep grades.
On 4wd trip with [MENTION=148218]JZiggy[/MENTION] off the California Coast near Big Sur, I learned that having your transfer case in 4Lo as opposed to 4HI can make a huge difference in your trans temp. When I was running in 4HI, my trans temp quickly climbed on the steep sustained fire roads we were on. After I stopped for a second time to let my trans cool down a bit, my buddy Jordan asked me if I was in 4hi or 4lo. When I said 4hi, he suggested I try 4lo and it was like night and day. If I would have kept driving in 4hi, I have no doubt I would have gotten the trans temp idiot light on my dash to light up because I was able to get it up to 230 degrees pretty quickly and we had a ton of more climbing to do. Once I shifted to 4lo, my trans temp never got above 170 degrees.
Now, if you're climbing steep and sustained paved grades, you can't exactly put your transfer case in 4lo because you would risk destroying your front differential and/or your CV axles. The best thing you can do in this situation is first be monitoring your trans temp and know when it's time to pull off for a little while and allow your trans temp to drop down a bit before continuing. If you had manual hubs, you do have the option to switch your transfer case into 4lo and have the front hubs unlocked so you could benefit from the lower gearing but avoid damaging your differential and/or CV axles.
Crookedcat
