Black Rhino Cinco Wheels fit?
Runnin4MO
Rig info:
-Metal Tech Front Bumper
-Eibach Pro Truck Lift: +2.75" Front, +1" Rear
-Picking up some UCAs shortly.
I'm a big fan of the Black Rhino Cinco wheels and wanted to know if anyone else has these installed? What are your thoughts on quality and what is your setup?
Their info:
17x9.5
Offset, 2 options: -18 or +12
Them being at 9.5 wide, I'm wondering if the +12 version may be to far into the wheel well and not fit at full lock... and again, being 9.5 how far out will -18 push the wheel past the fender?
I'm looking at pairing them with the RIDGE GRAPPLER 285 /70 R17
Thank all for the help!
No experience with the wheels, but
+12 on a 9.5 wheel will likely not fit. That's like a 5.7" backspace which will likely rub your spindles.
-18 will fit, but not sure how much it will stick out. If you're concerned about eating your fenders at bump, get extended bumpstops. If you're more for the wideboi look, then you're good.
Thanks for the info!
Was looking at the custom offsets site at 9" at -12, was told that's similar and it's showing less then 1" past the fender so I'm good with that, not ridiculous wide.
mek
