Brake pad thickness and frozen calipers.
Robs08Runner
Hey guys,
My brakes are coming up on eight years old and have about 6mm left. I am planning on changing the pads and flushing the system in 7 or 8 months. Do you guys think changing the pads a bit early and flushing might lesson the chance for frozen calipers down the road?
Hey guys,
I'm not sure if it will make a difference or not. I had both sides freeze in the front, in different years. Both times I had some padding left, enough for another 6 months but I get snow and ice here so I like to change them before the winter comes (if they're due for it in my later winter). Obviously if they're due for a change in the spring, summer and fall, I wait as much as I can. I hate being on the icy cold ground doing this in 20 degree weather.
If you think you're going to keep your '08 for a while, you may just want to change the calipers anyway. Just my 2 cents.
I forgot to add, my first freeze came during a motor vehicle inspection. My pads were just changed 5 months prior and had plenty of life left. Since mine has 2 calipers per side, the mechanic told me that only 1 was failing and that with the other one working, he could not fail me on it entirely. So I passed and then got a new caliper after that.
My second freeze did have some life left but would have fallen in direct winter for changing and that is when I discovered my other side froze. Dammit, at least it was warm out and I could spend some time working on it.
Wow, you've had some bad luck there. The positive for me is that mine has only been in the salty conditions for two winters.
Yeah I wasn't happy. I think my first freeze came in 2010, 2011. My second was 2013, the same year both my front wheel bearings went bad.
Hey guys,
Lubing the caliper pins might help.
I agree, those pins must let the pad slide freely. My firebird has problems with that. Will definitely make sure they're greased when it goes back together.
