Bumpers
Victory 4x4
Official Vendor
Our Blitz winch bumper for the 5th generation Toyota 4Runner is designed to integrate with your factory front bumper facia for a clean look with maximum recovery options. This made in the USA bumper features an integrated 20" lightbar mount, 3/4" recovery tabs, plus provisions for many industry standard winches. A fairlead block off plate is included for those that don't yet have, or need, a winch. The bumper is available in a 2 stage satin textured black powdercoat over durable zinc primer finish, or in bare metal.
  • CNC cut and formed from .188" steel.
  • Compatible with most 8-10k non-integrated solenoid or removable selenoid winches.
  • Some integrated winches will fit with a power steering return hose reroute.)
  • Built in provisions for a 20" light bar (22" max mounting width.)
  • Proudly designed and made in the USA.
  • Does not fit Limited Trim 4Runners.
4Runner Front Winch Bumper | Blitz w/Tube | 5th Gen (14+) - Victory 4x4
4Runner Front Winch Bumper | Blitz | 5th Gen (14+) - Victory 4x4
Strike Front Winch Bumper
Strike 4Runner Front Winch Bumper | 5th Gen (2014+)
When you need extra tire clearance, maximum protection, plus recovery options for your 4Runner; our Strike Series front bumper is a perfect choice. This made in the USA bumper features an integrated 20" lightbar mount, 3/4" recovery tabs, plus provisions for many industry-standard winches. This version also includes a bull bar for extra front end protection. The bumper is available in a 2 stage satin textured black powder coat over durable zinc primer finish, or in bare metal.
  • CNC cut and formed from .188" steel or .250" aluminum.
  • Available with or without 1.75" x .120" and 1.25" x .120" tube work for added grill protection.
  • Built-in provisions for standard 3"x3" cube lights.
  • Built-in provisions for a 20" light bar (22" max mounting width.)
  • Requires cutting part of the factory plastic bumper cover.
  • Hardware Included.
  • Will work with the TRD skid plate.
  • Will not work with Limited models.
4Runner Front Winch Bumper | Strike w/ Tube | 5th Gen (14+) - Victory 4x4
4Runner Front Winch Bumper | Strike | 5th Gen (14+) - Victory 4x4
Modular Rear Strike Bumper & Adventure Carriers
When you need maximum protection, recovery options, and a modular swingout system; our Strike Series rear bumper is the perfect choice. This made in the USA bumper features integrated cube light mounts, 3/4" recovery tabs, and built-in provisions for dual swingouts that can be added or removed at any time! The bumper is available in a 2 stage satin textured black powder-coat over durable zinc primer finish, or in bare metal.
  • Built-in hitch capable of the factory tow rating.
  • Built-in provisions for cube lights.
  • Built-in provisions for left and right Adventure Carriers (can be added at any time).
  • Built-in Hi-Lift jack points.
  • Bolt-on installation.
4Runner Rear Bumper | Strike | 5th Gen (10+) - Victory 4x4
Adventure Carrier | Rear Bumper Swing-out - Victory 4x4
Universal Tire Mount - Victory 4x4
https://www.victory4x4.com/product/UNI-HLM.html
Fold Down Table | Adventure Carrier - Victory 4x4
https://www.victory4x4.com/product/UNI-DJC-PC.html
Are the rear bumper adventure carrier swingouts compatible with a hatch mounted ladder? I have a C4 fabrication ladder currently installed that I want to retain for access to the roof and wanted to know whether the dual swing outs would work with that in place. Specifically, I plan on having the driver side swingout/adventure carrier configured for a dual jerry can set up.
It will not work with the ladder, but you could just run a driver side carrier or get both and add a Carrier Ladder.
Blitz bumper
Are there any plans for high clearance add ons for the blitz bumper? They would be a really awesome addition.
Maybe I missed it, does this work with the radar in the newer 5th gens?
DJNutshell
